Author Topic: Springs or Suspension Kit? And which ones?  (Read 3204 times)
Offline majinvash
  • Eat, Sleep, Snowboard
« on: December 30, 2012, 04:41:50 pm »
Hi
Looking to improve the handling of my ED30 without going too low or having a harsh ride.
From what I can research on this forum you all seem to recommend the H&R or Eibach when it comes to just springs.
I am looking for a 30mm drop max, so both of these seem to do and you all say the ride is pretty good after.
What I am worried about is the shocks going or becoming bouncy due to having to over work with the now shorter springs... Is this something I should be worried about?
So was thinking about going for a new suspension setup and have it done in one go.
I know I can get a better set of springs and shocks for my money than a coil-over set.
But there are a lot of options and I would appreciate some recommendations.
My end aim is to just tighten up the handing a little, I am never going to take it on track but its just a little more wallowy than I would like for spirited driving.
I already have a Superpro ALK to go on and just want to keep to as close as OEM ride quality ( If not improve it ) as possible.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Springs or Suspension Kit? And which ones?
« Reply #1 on: December 30, 2012, 05:14:05 pm »
It looks like you've done your research as you've established Eibach & H&R being the springs recommended on here.
I'm guessing you've seen what people say about ride quality on both? Not much that can be added really, they are both a little firmer than stock but still ride really well.
Your best replacing your shocks at the same time as lower springs will put more strain on them, the OEM shocks still work really well with both types of springs  :happy2:
Offline Baz300
« Reply #2 on: December 30, 2012, 05:16:59 pm »
I have a bilsten b12 kit it came with eibach sport line springs and I'm really happy with this setup, it only lowers the Gti around 20mm
You should fit the WALK kit at the same time as the suspension so that you only have to pay for wheel alignment once.
Offline paulk
« Reply #3 on: December 30, 2012, 05:22:32 pm »
my ed30 had vwracing springs , sat mint wasnt harsh and stook to the track like glue
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: December 30, 2012, 05:25:19 pm »
^^^Great track shot! Is that a Capri and a Transit in the background?  :laugh:
'07 Red manual
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #5 on: December 30, 2012, 05:25:30 pm »
Stook  :rolleye:
Offline paulk
« Reply #6 on: December 30, 2012, 05:26:36 pm »
Stook  :rolleye:
oh thanks STUCK ....must be hard for you
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: December 30, 2012, 05:26:48 pm »
in your shoes I would
H&R springs
H&R ARBs
Register on the group buy today (it ends tomorrow) http://www.mk5golfgti.co.uk/forum/index.php/topic,55953.0.html
then add the Superpro ALK or wishbone upgrade if you have the cash spare.
That will no doubt be less cost than coilovers or a spring/shock combo but id wager its as good if not even better in the handling dept and will retain a better ride quality.  Then at a later date add some B8 dampers in the mix and the car will be perfect.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: December 30, 2012, 05:58:24 pm »
H&R springs
H&R ARBs
Thats a decent setup  :happy2:
Although he said he already has the Superpro ALK  :wink:
Offline peter
« Reply #9 on: December 30, 2012, 06:03:25 pm »
Come on guys, don't you read the thread before posting! He already has a SUPERPRO ANTI LIFT KIT fitted, if you don't know this is an alternative to the overated  W.A.L.K  :rolleye:
ED30, Custom stage 1 remap,  THS FR3 engine mounts, Helix clutch, AP coilovers, W.A.L.K, Powerfex lower front control arm bushes, Heko wind deflectors
Offline AaronMc
« Reply #10 on: December 30, 2012, 06:27:29 pm »
I have Eibach Springs on ED30 and give a very nice comfortable drive without feeling crashy, and also make the car handle vey well..
Also looks just the right height on springs..
« Reply #11 on: December 30, 2012, 06:36:00 pm »
I can vouch for H&R's.
Coped well at the Ring too  :happy2:
Yes they are different cars  :wink:
Offline Aweful_Truth
« Reply #12 on: December 30, 2012, 10:09:09 pm »
my gti running Eibach springs and 19" wheels, love them, they dont compromise the ride, handling is great and car sits so pretty! and a fraction of the price too
To Bad, So Sad, Bye Bye!
Offline ripmateyy
« Reply #13 on: December 30, 2012, 10:12:30 pm »
What's the drop on this?
« Reply #14 on: December 30, 2012, 10:22:32 pm »
i believe its 30-35mm, the back is probably a fraction (maybe 5mm max) lower than usual as the boot has a sub and a couple of car batteries in it
