September 22, 2024, 01:36:09 pm
All Things Mk5
How to Guides / Troubleshooting
Radiator fans draining battery
Topic: Radiator fans draining battery (Read 1261 times)
steven0555
Taking part
-Given: 0
-Receive: 1
January 02, 2013, 04:39:16 pm »
Hi guys,
Had my ed30 for about 3 months now and had zero problems until I came back home after being at the girlfriends folks over christmas. Went to start the car a couple days ago and the battery was flat. Thought it could have been the cold weather and lack of use that drained it. Jump started the car with a booster pack and went for a drive. Came back and turned the engine off. Discovered that both the radiator fans are running even thought the car engine is off. They keep running until the battery is flat. Anyone else had this problem? How did you solve it? Had to pull the fuse to stop the battery going flat.
Steve
john87
Won't Shut up.
-Given: 11
-Receive: 53
Re: Radiator fans draining battery
Reply #1 on:
January 03, 2013, 09:53:05 am »
sounds like you have a faulty coolant temperature sensor, or something else causing the fans to stay on. My fans have never stayed on after ignition off...
S2 Ant
Won't Shut up.
-Given: 9
-Receive: 21
Reply #2 on:
January 03, 2013, 01:00:24 pm »
Do the fans come on as soon as you started the car?
I've had my fans run for a short time after the car was turned off on a hot day, but otherwise its a rare occurance. As above, it might be a faulty sensor or switch somewhere causing it
Ant
All Things Mk5
