Author Topic: ABS ESP Tyre Pressure Lights all on.  (Read 1578 times)
Offline Guy Incognito
« on: January 03, 2013, 01:51:03 pm »
My 56 plate GTI was unused over the festive period.  On my way to work last night these 3 warning lights came on.  Stopped and checked the tyres as that's the only thing I could ensure were ok, and they were.  The ABS light doesn't go out when I turn ignition on then after driving a short distance the other 2 lights come on.
I assume the only thing I can do is get it plugged in somewhere to read the faults.
Any recommendations in the Lanarkshire/Glasgow area?
Offline GTI-Pirelli
  • -Receive: 27
Re: ABS ESP Tyre Pressure Lights all on.
« Reply #1 on: January 03, 2013, 02:22:38 pm »
A faulty wheel speed sensor or connection?
Tyre pressure warning monitors all 4 wheels and then senses when one is rotating faster than the others (flat tyre = smaller circumference)
ABS will look to see if a wheel has locked under braking.
ESP will check for differences in wheel speed to compensate for lack of traction.
Just a thought. Try to get it plugged in:
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Good luck.
2017 Audi S4
« Reply #2 on: January 09, 2013, 11:41:55 pm »
Good luck.
Cheers.
Haven't had the time to get it checked.  Will update when I do.
