Author Topic: 'G' revision D/V failiure? which one to get now.........  (Read 6035 times)
Offline heavyd
  • -Receive: 29
Re: 'G' revision D/V failiure? which one to get now.........
« Reply #30 on: January 04, 2013, 10:54:28 am »
Benfield vw near me still sell them, the parts guy checked and said they were in stock at the central warehouse...........
I got a revision g anyway, a million miles better than the original b version !
He tried to find the info for the 'D' and couldnt order from the central warehouse? You dont happen to be from Shields by any chance do you :wink:
Offline Mk5 GTian
  • -Receive: 37
« Reply #31 on: January 04, 2013, 11:09:16 am »
I have just contacted VW Colbournes Guildford, see this thread which I have put up as it relates specifically to my car:
http://www.mk5golfgti.co.uk/forum/index.php/topic,59206.0.html
Using the part number for Rev D in the thread, I was told it could be ordered and would be with them on Monday.
Offline donovan2123
« Reply #32 on: January 04, 2013, 11:16:17 am »
The fact your car is modified shouldn't make a difference. You boughta part and it has failed . Question is why and are you sure it was diverter valve and not another issue? I mean did you log boost?
Just interesting that's all :happy2:
Offline heavyd
  • -Receive: 29
« Reply #33 on: January 04, 2013, 11:21:40 am »
Well the car drives better with my old 'c' valve on, boost spiked at 1.8bar with the 'g' valve on, and the reoccurring faulty n249 valve fault code hasn't appeared since I changed it over :happy2:
There argument will be the extra boost caused it to fail. The parts man is a good bloke, so of he could have done it, he would have
Offline donovan2123
« Reply #34 on: January 04, 2013, 11:24:09 am »
Interesting keep us posted as maybe fault only flags up under certain conditions which you have not ye reached .
Offline 56OctyVRS
  • -Receive: 72
« Reply #35 on: January 04, 2013, 11:26:40 am »
Probably the D isnt showing as available due to being superceeded by the C a few months back. I would presume you are K04 and it is an easy job to replace the dv. I would opt for the another G again. The D can leak from new and in my car it felt sluggish low down and the engine wasnt as responsive as it is with the G. I treat dvs as a wear and tear item like brakes etc.
Offline heavyd
  • -Receive: 29
« Reply #36 on: January 04, 2013, 11:36:36 am »
I only revved the car, and it came back on with the 'g'  :surprised:
Heres teh boost spike
The revision 'C' wasnt available at the dealers either, that was classed as being superceeded by the 'G' also :happy2:
« Last Edit: January 04, 2013, 11:38:21 am by heavyd »
Offline Mk5 GTian
  • -Receive: 37
« Reply #37 on: January 04, 2013, 11:37:34 am »
The D is available from VW. I could have ordered one today.
Offline heavyd
  • -Receive: 29
« Reply #38 on: January 04, 2013, 11:39:23 am »
Must be the north south divide then :signLOL:
Saintsteve
« Reply #39 on: January 04, 2013, 03:53:24 pm »
Maybe there is a difference with your engine ? AXX is different to say one of the other engine version types?
Offline sandancer
« Reply #40 on: January 04, 2013, 05:30:12 pm »
Sure am, is it that obvious !
Are you as well ?
Offline Chrismeardon
« Reply #41 on: January 05, 2013, 12:03:50 am »
Is VW the cheapest place to buy these from or do any of the traders sell them cheaper?
Offline Raffe
« Reply #42 on: January 05, 2013, 08:00:53 am »
 :congrats:is it worth cosindering the Forge version which looks to be fairly substantial?
Offline heavyd
  • -Receive: 29
« Reply #44 on: January 05, 2013, 11:09:43 am »
Went to collect mine, got the parts bloke to foam ekta search for the k03 engine
Here's the listed d/v for the k03 cars
