Author Topic: exhaust  (Read 2334 times)
Offline biglad65
exhaust
« on: January 06, 2013, 07:00:51 pm »
hi does anyone now if a 2.0 tdi 170 exhaust back box will fit a 1.9 tdi car thanks
Re: exhaust
« Reply #1 on: January 06, 2013, 07:15:07 pm »
people normally  get the gti one as its easy to get hold of but you will need a adaptor to make it fit
« Last Edit: January 06, 2013, 07:52:22 pm by maxitrol »
AA
Re: exhaust
« Reply #2 on: January 06, 2013, 07:50:25 pm »
Pretty sure the enrty point is different As maxitrol says GTI much easier to source
Offline biglad65
Re: exhaust
« Reply #3 on: January 06, 2013, 07:53:51 pm »
does anyone know where i can get a adapter to make it fit  cheers
Re: exhaust
« Reply #4 on: January 06, 2013, 07:56:29 pm »
Any good garage that makes exhausts can make one. For you
Offline biglad65
Re: exhaust
« Reply #5 on: January 06, 2013, 08:01:28 pm »
only know fitters in leeds
Re: exhaust
« Reply #6 on: January 06, 2013, 08:09:41 pm »
Offline biglad65
Re: exhaust
« Reply #7 on: January 06, 2013, 09:12:32 pm »
so the 1.9 tdi back box is the same as the gti apart from the ends thanks
Re: exhaust
« Reply #8 on: January 06, 2013, 09:19:27 pm »
a different  bore  size that's all-just need to change the rear valance
Offline biglad65
Re: exhaust
« Reply #9 on: January 06, 2013, 09:23:08 pm »
sorry but not any good at this thanks for your time but when you say bore is that the joint to connect to existing pipe
Re: exhaust
« Reply #10 on: January 06, 2013, 09:26:41 pm »
one of the exhaust  pipes is smaller so you need a garage to make you a piece of pipe that fits your car and the gti back box
Offline biglad65
Re: exhaust
« Reply #11 on: January 06, 2013, 09:29:05 pm »
thanks maxitrol for your help
Re: exhaust
« Reply #12 on: January 06, 2013, 09:33:39 pm »
Offline biglad65
Re: exhaust
« Reply #13 on: January 24, 2013, 04:43:44 pm »
got a gti exhaust back box but it as another box in front of it do i need to cut this other part off to fit it to my tdi or does the the lot fit with the 2 boxes thanks
Offline skard
  • -Receive: 245
Re: exhaust
« Reply #14 on: January 24, 2013, 04:49:30 pm »
When I cut mine I cut it about 15" from the backbox to remove the centre box and ordered a reducer sleeve off ebay, so it looked like this a bit...!
   __|__
  |____|
 :grin:
