Author Topic: Bit of an oddity...  (Read 1891 times)
Offline Bane
  • "I was born a handsome man and now I'm half a goat
Bit of an oddity...
« on: January 08, 2013, 01:42:28 pm »
Started the car today as normal and I noticed that the ESP and the tyre pressure light didn't go out.
I pressed the buttons and that did nowt.So I left it.
The car drives fine,with no problems and I've been to the garage and checked the pressures and topped up where neccessary and that has made no difference to the tpm.
It's just strange that without any warning signs and the car parked up overnight,that both these lights should decide to stay on.
Anyone experienced this?Any ideas before I head of to get it checked out with a diagnostic?
  • -Receive: 453
Re: Bit of an oddity...
« Reply #1 on: January 08, 2013, 03:32:03 pm »
Could just be a sensor issue or worst case your abs unit is faulty. A scan should point you in the right direction.
Offline MightyMullet
  • Penzance, Cornwall
« Reply #2 on: April 13, 2014, 01:23:20 pm »
Just wanting to know if any light was shed on this, happened to mine today. Started the car and the tyre pressure light and esp both remained on. Neither will turn off at the button.
« Reply #3 on: April 13, 2014, 02:38:00 pm »
Ok this problem has just rectified itself after another short drive, so i guess nothing to worry about for now.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #4 on: April 13, 2014, 05:34:35 pm »
Keep an eye on it as mine done that then a month or so later the EPC light joined in along in a loss of power and an occasional EML. Tuned out to be the throttle body.
« Reply #5 on: April 13, 2014, 08:40:32 pm »
Fantastic news, does it mean its pretty much anything then? Seems different things occur.......
......anyone want a reflex silver 3 door? :P
Offline chowgar
« Reply #6 on: April 14, 2014, 12:05:55 am »
when you say rectified itself do you mean the lights have gone out or you have scanned the car and there are no faults... the lights will go out by themselves as they run on a key cycle so after a number of turns of the key they turn off...
