Author Topic: Rcd310 into a mk5  (Read 1206 times)
gaz b
Rcd310 into a mk5
« on: January 09, 2013, 05:09:42 pm »
Hi chaps, just a quickie!
Will a rcd 310 plug straight into a mk5? Also would there be battery drain issues?
Thanks in advance :happy2:
Offline apples12
Re: Rcd310 into a mk5
« Reply #1 on: January 09, 2013, 05:11:32 pm »
Hi,
I had an RCD310 in my mk5 whilst my RNS was being repaired - wicked bit of kit. wont have battery drain issues if your car has a gateway later than revision K or is newer than (IIRC) 56 plate. my RCD310's sitting on the shelf gathering dust now!
MK6 GT TDI  - CW - LUX pack
GONE
gaz b
« Reply #2 on: January 09, 2013, 06:05:20 pm »
Cheers apples, where is the gateway so I can check it!  :ashamed:
Currently trying to sell my rcd and the potential purchaser wants to put it into his mk5.
The 310 is a big step up from the 210 that came in my transporter. I'm due a van change soon or would be keeping it! :happy2:
Offline torque777
Re: Re: Re: Rcd310 into a mk5
« Reply #3 on: January 09, 2013, 06:07:23 pm »
Hi,
Yes above is true , ive just put a rcd510 in my golf on a 57 plate , I had my chassis number checked and its on a 08 build spec and has later gateway so no battery drain
sent using my own fingers
