Author Topic: Rear window condensation  (Read 858 times)
Offline phil197
« on: January 09, 2013, 09:54:29 pm »
The wife has tried to explain this one so I'm slightly confused...
Car is left on drive overnight..windows clear, goes to work car left in car park all day, when wife drives car home, inside of rear window has fair amount of condensation on it and is just clearing by the time she is home, around 11 mile journey with de- mister on.
Am I missing something and should it clear without condensation or is she moaning for good reason.
Advice please guys
Thanks!
Offline OSB
  • -Given: 32
Re: Rear window condensation
« Reply #1 on: January 09, 2013, 10:13:59 pm »
I had a similar problem with my Mondeo a few years ago. Turned out there was a water leak into the boot, which collected in the wheel well. When cold not much happened, but when driving (and the car was warmer) some of the the water 'evaporated' and condensed on the cooler rear window.
I never really found where the water was getting in to the boot area, so I drilled a small hole in the lowest point, stuck a 25mm length of plastic tubing into hole so water would not come in, but would drain out...... no problems from then on.......
Have a look in the boot/wheel well. I read somehwere that there can be leaks in these cars.
