Author Topic: Instructions for Retro fitting an armrest  (Read 1620 times)
Davo12
« on: January 10, 2013, 05:17:37 pm »
Hi, i'm new to the site and just purchased my first VW Golf GTI but i'm wanting to fit an armrest as it doesn't have one. I have purchased the armrest but don't have any instructions!! Can anyone help me out?
Offline Lone_Par
Re: Instructions for Retro fitting an armrest
« Reply #1 on: January 10, 2013, 06:05:00 pm »
http://translate.google.co.uk/translate?hl=en&sl=da&u=http://vwfanatic.dk/Tips/G5Armlaen.html&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D1K0%2B863%2B323A%2B71N%26hl%3Den%26rlz%3D1G1GGLQ_ENUK276%26sa%3DG%26pwst%3D1
Once you get going, you'll find your way.
I fitted one last night. Depending on the version, I would recommend dismantling the bulk of the arm rest before fitting and then build it up bit by bit.
Offline andybon
« Reply #2 on: January 10, 2013, 07:35:51 pm »
When I got mine it came with a set of destructions, pretty easy to fit together really.
How hard can it be?
Davo12
« Reply #3 on: January 10, 2013, 08:15:39 pm »
That's Great!!
Thanks for the instructions and advice, I'm going to have a go at it on the weekend!!
Offline torque777
Re: Re: Instructions for Retro fitting an armrest
« Reply #4 on: January 10, 2013, 08:18:07 pm »
Thats interesting , ive got one coming for mine so need to strip mine down
sent using my own fingers
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #5 on: January 10, 2013, 10:06:12 pm »
It's a nice easy job, unless you want to do the vent pipes too which requires a little more work. But definitely do bit at a time - main cage with armrest lid first, then slip over the plastic cover, make sure you push the clips down the side correctly. A couple of screws at the back to attach to the cage. Then push on and downward the rear plastic with the vents (without the Cupholder) then push in the Cupholder, fold down and put in the last two screws and viola  :happy2:
