Author Topic: abs, traction control, steering wheel lights on, help!!  (Read 7324 times)
Offline biffobear
« on: January 11, 2013, 03:43:13 pm »
abs, traction control lights, lit up on dash, so carried out scan, showed up as 00290- ABS wheel speed sensor, rear left,(g46) 003 mechanical failure.
So i fitted a new sensor, checked the wiring getting a live feed down one of the wires, other seemed ok, so rebuilt and rechecked, reset, lights still on, now getting another message,  00290 ABS wheel speed sensor, rear left,(g46) 012 electrical fault in circuit.
Next day door controller on ns door stopped working so i disconnected the battery for a couple of hours to reset, when i started the car  the steering wheel light appeared on the dash, so i carried out basic settings for steering angle, it checked out ok , so carried out Steering limit stop adaption, now the steering is very heavy.
So what do i do now, will the abs fault have to be fixed before the steering will reset?, and any suggestions what to do next regarding the abs fault, dont want to renew abs reluctor ring as part of bearing and expesive unless neccessary, thanks for any help.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73EFF074124529802CE
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46) Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Revision: 00H11001
   Coding: 0004738
1 Fault Found:
            012 - Electr
            003 - Mechanical Failure
Offline donovan2123
Re: abs, traction control, steering wheel lights on, help!!
« Reply #1 on: January 11, 2013, 05:29:29 pm »
Using vcds go to measuring blocks and measureeach wheel then hhit log and drive round to for min or 2 and post upthe log here .
Offline biffobear
« Reply #2 on: January 11, 2013, 07:39:09 pm »
Do you mean the abs logs from each wheel? Can get logs tomorrow' did one yesterday' getting identical readings from all wheels except nsr which had no reading
Offline donovan2123
« Reply #3 on: January 11, 2013, 09:30:32 pm »
Yes. Have you done it again  since replacing abs sensor?
Offline biffobear
« Reply #4 on: January 11, 2013, 09:41:21 pm »
Yes, did another measuring block check, same again, readings for all wheels except nsr, no reading. And the 012 electrical fault when scanned.
Offline donovan2123
« Reply #5 on: January 12, 2013, 09:31:34 am »
If there is no reading on sensor u replaced then you need to double check fitting. Make sure sensor is all the way in which and make sure the wiring is fine. Last check connector that pushes on to sensor as it require ssome strength to get it on properly. Tug wiringand of cconnector comes of sensor then it's not on properly.
Offline biffobear
« Reply #6 on: January 12, 2013, 11:58:15 am »
So do you tbink that because the first scan was mechanical failure " then after changing the sensor the second scan was" electrical fault"  this points to the fault pointing to either faulty or incorrectly fitted sensor, or wiring fault, and not the reluctor ring?.  And will the abs fault prevent the steering resetting?. Will try to find time today to have a look at it again, the wiring connector was hard to get back on again but I thought I had managed to get it to clip back on' cheers.
Offline brough74
« Reply #7 on: January 12, 2013, 01:17:21 pm »
Donavan knows his stuff, he helped me with the same kind of issue.
Like he said check the connectors in tight, the wiring is ok and finally check the pins in the sensor (use a mirror and a torch if you dont want to remove it ), the pins are easy to bend if you dont get them lined up properly.
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline biffobear
« Reply #8 on: January 12, 2013, 01:57:57 pm »
Probably won't get time at weekend , working, so will provide update when  time allows, cheers
Offline donovan2123
« Reply #9 on: January 12, 2013, 03:35:55 pm »
Electrical fault is either a dodgy sensor(again), dodgy wiring or connector not fully pushed on correctly or bent pins.
Mechanical failure is most likely your ring however somthing has changed since fitting new sensorhence a different fault.
I would quickly get under car and take quick look.
However be warned once you solve the electrical fault you may get the mechanical fault back and in this case it will be the ring.
Seeing a lot of these abs rings going recently must be the bad weather lol.
Offline biffobear
« Reply #10 on: January 12, 2013, 04:13:20 pm »
Thanks Donovan, your advice is greatly appreciated, might be Monday now before I get to check it, will keep you informed, cheers.
