Author Topic: Slipping Clutch  (Read 6780 times)
Offline alfboden
Re: Slipping Clutch
« Reply #45 on: March 10, 2013, 08:06:35 pm »
Do you mean upgrade the clutch and still use the OEM dmf?
Yes, but I may just go with oem clutch as well as I'm only ever going for stage 1.
Thoughts?
Black 5dr Edition 30 No. 1045
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Slipping Clutch
« Reply #46 on: March 10, 2013, 08:15:26 pm »
Depends which map mate... the clutches slip due to the torque.. I have a middle of the road map making ~280lb/ft and have had no problems in nearly 40k of mappage (car on 109k original clutch and DMF!  :confused:)... although some with more aggressive maps, pumping out 320lb/ft+ slip from day one.
Offline alfboden
Re: Slipping Clutch
« Reply #47 on: March 10, 2013, 08:20:51 pm »
Ok thanks, I've got an ed 30 and will be going for bluefin stage one so its 300 lb ft of torque.
