Author Topic: Fitting autotech pump on stage 2  (Read 827 times)
Offline 55golf
« on: January 12, 2013, 11:45:42 pm »
My ed 30 is running a stage 2 r tech map, would it be ok to fit an autotech fuel pump and drive around for a couple of weeks before I get it remapped again
Re: Fitting autotech pump on stage 2
« Reply #1 on: January 12, 2013, 11:48:53 pm »
Yes...  :smiley:
Offline PDT
  • -Receive: 142
« Reply #2 on: January 13, 2013, 11:07:40 am »
Yes, no issues at all driving with internals fitted as fuel pressure demand is till the same.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: January 13, 2013, 11:17:29 am »
Yes x 3. Do you all check the cam follower often with the Autotech hpfp? Mine wore through a c/f after 5.8k miles. I think because the c/f got put back in when installed by the mech tech. They took care of the cam and hpfp, but I had to pay for the following hpfp upgrade. So I chose APR b/c SKEARED! I would try Autotech again if needed b/c my circumstance seemed related only due to the follower looking good and the mech tech using it again. I planned to check after 10k miles, but...never got there. I also had the 'A' version cam that vwoa recalled. They pointed at the A-cam as the problem.
