Author Topic: BKD/BNM Heads  (Read 5721 times)
Offline DFish
BKD/BNM Heads
« on: January 13, 2013, 08:43:17 pm »
Does anyone know if the BNM head will fit and work with a BKD engine, and also if it suffers the same leaky head issue as the BKD's?
Fish
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #1 on: January 13, 2013, 08:46:25 pm »
BMN doesnt suffer not sure if it will fit though
Offline marko
Re: BKD/BNM Heads
« Reply #2 on: January 13, 2013, 08:51:05 pm »
different injectors so i would guess its a different head...
someone here with ETKA will be able to check it out
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #3 on: January 13, 2013, 08:58:57 pm »
Deffo different injectors, BMN has the troublesome Siemens PPD's
I know of someone who has fitted PD140 injectors into a PD170 though so get round the issue of them injectors so.. could be possible
Re: BKD/BNM Heads
« Reply #4 on: January 13, 2013, 09:01:24 pm »
i was told they wouldn't fit
Offline DFish
Re: BKD/BNM Heads
« Reply #5 on: January 13, 2013, 09:22:00 pm »
Thanks for the replies. I think I might drop DevonMikeyBoy an email, as he's played with different combinations.
Fish
Offline Dannyboy88
Re: BKD/BNM Heads
« Reply #6 on: January 13, 2013, 09:25:57 pm »
Can't you fit the newer revision BKD head which is the C version I think? Its ment to be stronger than the A and B version.
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #7 on: January 13, 2013, 09:35:38 pm »
a guy abroad has done it, hes also fitted the PD140 ecu , but the car was running like a pig
Offline marko
Re: BKD/BNM Heads
« Reply #8 on: January 13, 2013, 09:43:03 pm »
why???
put a pd140 ecu in a car with 170hp engine
 :ashamed:
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #9 on: January 13, 2013, 09:57:33 pm »
why???
 :ashamed:
At the time there was no way of the getting the Siemens PPD ECU and Injectors of producing the amount of boost he required for his hybrid turbo so to get round this he fitte the Bosch set up then he could get the boost he needed, The Siemens ECU has got like a boost limiter on it that cant be removed
Since then some developments have been made and the Siemens ECU can now be tricked into making more boost than it thinks it is
Offline marko
Re: BKD/BNM Heads
« Reply #10 on: January 13, 2013, 10:17:12 pm »
 :happy2: :happy2:
very good
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #11 on: January 13, 2013, 10:18:32 pm »
Lad called Kilner in UK has got a Hybrid PD170 set up now producing about 260bhp, hes also getting another Custom Turbo made for it before fitting bigger injectors
Re: BKD/BNM Heads
« Reply #12 on: January 13, 2013, 10:41:30 pm »
his build thread is amazing -I was thinking ogre going down the bigger turbo dark side and  injectors but think i will be happy  between 220-240 but you never know
Offline AndrewJB
  • die gelbe Baron
Re: BKD/BNM Heads
« Reply #13 on: January 13, 2013, 11:12:25 pm »
i sold my PD170 when i was running Stage2+ Shark Mapping which went very well
I was convinced nobody would run a hybrid turbo.. Jamie has proven me wrong, hes a nice lad and he's not scared to show up companies who are lieing!
Sometimes i wish i had kept the PD170 now
Offline Matto
  • -Receive: 116
Re: BKD/BNM Heads
« Reply #14 on: January 13, 2013, 11:24:19 pm »
I've been slowly working my way through yours and Kilners build threads on TDisport.
