Author Topic: Had my gti remaped today at r tech  (Read 8477 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Had my gti remaped today at r tech
« Reply #60 on: January 19, 2013, 09:27:20 am »
Meth helps suppress pre detonation, it take the Ron rating of the fuel higher.  The water has oxygen in which aid the combustion.   Both liquids also aid combustion temp cooling.
01455 617233
Offline gigolo456
« Reply #61 on: January 19, 2013, 09:52:02 am »
Morning Nick, can I take it then that u do fit there kits? Are they tweaked around existing r tech maps, even tiv+??
Offline R-tech-Nick
  • -Receive: 30
« Reply #62 on: January 19, 2013, 01:36:28 pm »
Hi,
We don't supply or fit the kits dude.   You can run it on your current map and be fine, or you can book some dyno time and have the map custom setup to take into account the WMI.
01455 617233
Offline gigolo456
« Reply #63 on: January 19, 2013, 01:48:22 pm »
Ah ok, I will look into that then Nick! Will it work with the TiV update too?
Offline R-tech-Nick
  • -Receive: 30
« Reply #64 on: January 19, 2013, 10:54:45 pm »
TIV will work at any stage of tune.  Even stock map and boost, fuel and ignition it gains 12bhp
01455 617233
Offline gigolo456
« Reply #65 on: January 19, 2013, 11:27:42 pm »
I have found a source for the kit and fitting, apparently a lot more complicated, not to mention expensive than what I thought, but by all accounts the benefits and gains are big, so will be wanting you Nick plse to do me a custom map around the kit, including pre tuned and tuned dynos probably! Have you got a documented price for this sort of tuning plse Nick, bearing in mind I already have one of your Stage 1.5 maps?
Many thanks
Andrew
Offline R-tech-Nick
  • -Receive: 30
« Reply #66 on: January 20, 2013, 01:32:11 pm »
Many thanks
Andrew
You just pay per hour for dyno time to setup the WMi and mapping
01455 617233
Offline gigolo456
« Reply #67 on: January 20, 2013, 01:43:21 pm »
Cheers, may I ask plse what yr hourly rate for dyno and tuning is for the WMi is(hoping a morning appt wud cover it, lol!?) :$
