Author Topic: Rns 510 no sound! :(  (Read 13274 times)
Offline Jorj
« on: January 14, 2013, 11:13:17 pm »
I brought a rns 510 sat nav, and fitted it in and have no sound.
It reads the sd card files, finds all the radio station, reads cd and hdd but no sound at all. I scanned it using vag com and it's saying " speakers short to ground" but when I fit my standard unit, every thing works fine and all speakers work as they should! Spent alt of money and the guy showed me it working in his car but I tried it in my car and no sound
Re: Rns 510 no sound! :(
« Reply #1 on: January 14, 2013, 11:33:59 pm »
Is the connector to the back of the unit properly locked in?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: January 14, 2013, 11:35:15 pm »
did it come out of a car with the vw sound system
Cluster and Key coding
Location Great Yarmouth
Offline Jorj
« Reply #3 on: January 15, 2013, 12:03:33 am »
Im not sure if the car it came out of had sound system, I tried change the sound system settings in vag com but no joy,
When check fault codes, it comes up wit all speakers short to ground.
Could it be a faulty unit? When I add the standard unit, the speakers work fine.
Iv checked all connections and they are in properly and locked in.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=a1aq1gqsotjdin2b5r0on71pcq&/topic,19740.0.html
« Reply #4 on: January 15, 2013, 12:05:38 am »
But if you saw it working in his car... how can it have broken between then and now?
« Reply #5 on: January 15, 2013, 12:07:51 am »
Isn't there a speaker test you can do in VCDS?
« Reply #6 on: January 15, 2013, 12:11:13 am »
Yes there will be in the Radio section.
Offline Jorj
« Reply #7 on: January 15, 2013, 12:13:34 am »
I seen it working in his car and since then Iv had the sat nav sitting at home in the garage.
Iv tested the speakers threw the vagcom and all speakers make sounds when I test them.
It's strange fault. Gona find a good audio tech.
« Reply #8 on: January 15, 2013, 12:14:46 am »
Can you do screenshots of your coding?
« Reply #9 on: January 15, 2013, 12:17:11 am »
Sounds like a coding issue then if the speakers work in the output test.
Offline Jorj
« Reply #10 on: January 15, 2013, 12:22:41 am »
I'm gona try get screen shots, borrowed the vagcom off a mate.
Another problem was that when I used the navigation, it picked up my location that I was in Germany! Lol
Maybe it just need to be driven around for a while to pick up true position.
Offline Jorj
« Reply #11 on: January 15, 2013, 06:09:32 pm »
Ok so I took it to a vw independent specialist and he coded the sat nav. And said that it says
" left front speaker short to ground  " and " left rear speaker short to ground" fault code
He said that the "ic" for the left speakers might be blown.
Any 1 know any where that can repair this problem?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: January 16, 2013, 09:44:01 am »
try your old head unit and see if that still works. That way you can see if the speakers are faulty or not, But i have a feeling its got to do with the coding
Offline Jorj
« Reply #13 on: January 17, 2013, 01:51:24 pm »
Iv tried my standard head unit and it works fine, all speakers work. And when I fitt the rns 510 and done the vagcom speaker test, it wudnt play no sound out the left speakers but with the standard unit, all speakers work as they should!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: January 17, 2013, 02:06:37 pm »
has to be the coding, or you have a faulty unit
