Author Topic: Normal running Temp for TSI  (Read 12126 times)
Offline OSB
  • -Given: 32
« on: January 15, 2013, 04:28:17 pm »
What would you expect to find as the normal running temp? 90 deg on the gauge?
Mine rarely gets above 2 divisions back from that. Too low?
Also, how long to get up to temp? Mine seems to take about 5 - 6 miles of normal running. Is this normal?
Or does it all sound like a faulty thermostat?
Is this difficult to change?
Cheers for any advice
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Normal running Temp for TSI
« Reply #1 on: January 15, 2013, 06:19:58 pm »
Once up to temp it should stay bang on 90 all the time. It's usual to take quite a while to get up to that temp, especially in cold weather. I couldn't comment on whether yours might be faulty though.
Offline OSB
  • -Given: 32
« Reply #2 on: January 15, 2013, 07:34:04 pm »
Thanks - 90 is what I thought.
It's going into VW for some other stuff to be sorted, they can sort that as well! (Warranty issues.........  :confused: !)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: January 15, 2013, 07:44:11 pm »
MIne stays on the 90, unless i go down a long steep hill near ours when it drops below, using thedigital display fnction it normally is running 70-76degrees unless stuck in traffic.
Diesel Daily Hack.
Offline john87
  • -Receive: 53
« Reply #4 on: January 15, 2013, 10:07:04 pm »
Mine stays on 90 once it gets there, which often takes between 5-10 minutes depending on outside temperature.
Although possibly unrelated, my mates' 2003 A3 hardly ever reached 90 on the dash, which was diagnosed as a faulty coolant temp. sensor. Apparently common on those 1.8 turbo's
« Reply #5 on: January 15, 2013, 10:09:34 pm »
At least on the TSI you have an oil temp.
Offline Jussa
  • Bicester
« Reply #6 on: January 15, 2013, 10:25:17 pm »
You have one on the S3 as well.  Couldn't understand why they didn't give this to the MK5 GTi, my MK1 GTi even had this??  :confused:
I had to fit the Kufatec Bluetooth to m old MK5 GTi to get the oil temp function!!
Offline mtj2k
  • 1.4 TSi GT
« Reply #7 on: January 16, 2013, 11:10:24 am »
I have mk5 1.4 Tsi. Take forever to warm up but doesn't budge from 90 after 10-15 mins.
If i was into conspiracies I'd say that there was something stopping it from even the smallest of fluctuations.....
Offline OSB
  • -Given: 32
« Reply #8 on: January 16, 2013, 02:33:45 pm »
Thanks. 90 dead seems to be the figure. Confirmed by another vw workshop today.
Either the thermostat is faulty - opening too soon or stuck which would account for the slow warm up as well as the low running temp. Or the sender is inaccurate, possible. Or the gauge, very unlikely.
I'll find out tomorow and post the result.
Offline Gazza747
« Reply #9 on: January 18, 2013, 10:29:29 pm »
Did you find out what the issue was?
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline OSB
  • -Given: 32
« Reply #10 on: January 19, 2013, 08:45:04 am »
Well now .... I went to the garage and whilst the mechanic was listening to the noise from the N/S drive shaft, he agreed that the temp was incorrect. It was either the thermostat or the sender. More likely the sender.
When i pointed out the slow warm up and low heater output he changed to more likely the thermostat...........
When it goes in to have the N/S drive shaft noise sorted AGAIN ( they changed the O/S DS bearing last week despite the noise coming from the N/S!) they will sort the temp out..... I hope.
I'll let you know.
Thank goodness for a years warrenty! Otherwise I would have had to have covered a duff battery, seized rear wiper motor and rattling boot lid so far.........
Thimk I might join the 'Why I hate my GTI' thread!  :sad1:
Offline Gazza747
« Reply #11 on: January 19, 2013, 09:00:42 am »
I have a years warranty too, almost coming to an end.
I had the high pressure switch replaced early on and a new turbo fitted. It's been running fine since the turbo was fitted but i'm thinking on continuing with the warranty when this one runs out.
Offline OSB
  • -Given: 32
« Reply #12 on: January 19, 2013, 09:24:25 am »
I recon that would be money well spent.
When I told the After Sales Manager I thought I'd bought a VW not a Lotus he looked puzzled. "You know - Loads of trouble usually serious" Then he looked less than  amused...
