Author Topic: wheels & tyres  (Read 1900 times)
Offline candy turbo
wheels & tyres
« on: July 08, 2009, 07:44:14 am »
thinking of fitting 8x19 et 48 whats the best size tyres to use ? Cheers guys
Re: wheels & tyres
« Reply #1 on: July 08, 2009, 09:25:20 am »
Not sure but i think you would need a spacer on the front and the wheels would have a bit of poke.  :happy2:
Offline Jaywoo-GTI
  • -Given: 38
Re: wheels & tyres
« Reply #2 on: July 08, 2009, 09:51:32 am »
225/35/19 is the best tyre for that setup.
Re: wheels & tyres
« Reply #3 on: July 08, 2009, 09:54:41 am »
as above
Offline TurboTrev
Re: wheels & tyres
« Reply #4 on: July 08, 2009, 10:05:27 am »
as above, although 235/35x19 will be fine as well (better than 215s although these would fit).  My wheels are 8x19, ET50 with 235s and although they sit slightly within the arch, for the style of wheel I have that's fine by me.  Spacers would only be needed if you want to push them right to the edge of the arch and probably only for the back (8mm).
Offline VeeDubDan
Re: wheels & tyres
« Reply #5 on: July 08, 2009, 10:05:41 am »
Are you sure? Those sizes don't look too far off standard.
Re: wheels & tyres
« Reply #6 on: July 08, 2009, 01:52:15 pm »
Yes you are right, i dont know why but i read it as 9.5j ET 48  :signIWS:
Peskarik
Re: wheels & tyres
« Reply #7 on: July 08, 2009, 03:00:45 pm »
but 8mm spacers are non-centered.
Aren't we against noncentered spacers? Especially on the front?
Offline Mark_GTIV
Re: wheels & tyres
« Reply #8 on: July 08, 2009, 03:31:07 pm »
You can get 8mm spacers that are centered (spigoted).
e.g. H&R Trak+
« Last Edit: July 08, 2009, 03:33:09 pm by Mark_GTIV »
Offline candy turbo
Re: wheels & tyres
« Reply #9 on: July 08, 2009, 03:52:17 pm »
cheers every one , any one actually got that set up ? any rubbing etc . would never fit spacers again !!!!! :happy2:
Offline TurboTrev
Re: wheels & tyres
« Reply #10 on: July 09, 2009, 10:04:33 am »
That set up would fit without any rubbing.
As I said, spacers are not needed at all, but if someone is looking for a wheel/tyre set up that comes right to the arch edges, then spacers or a different offset wheel would be required.
