Author Topic: Another HID question....  (Read 2830 times)
Offline Veee-dubber
« on: January 17, 2013, 08:23:50 pm »
Evening all....
Firstly I know these are illegal.
I want to run a HID kit in some aftermarket Xenon headlights, I have auto lights and I want to keep this feature is this at all possible...?
Secondly... Can anyone reccomend a kit for me I want white light so 6k - 8k and obviously they will need to be compatible with the mk5's as I believe alot bring up the canbus error....?
Ive seen some of the kits have a film on that melts away when first ignited to help produce a better beem pattern, anyone had any expiriences with these at all?
Cheers All :)
 :drinking:
Re: Another HID question....
« Reply #1 on: January 17, 2013, 08:24:53 pm »
I take it you wanted this in the MK5 section?
Offline jonnym
  • -Given: 40
« Reply #2 on: January 17, 2013, 08:57:17 pm »
yeh you selling any HIDs?  :signLOL:
In theory if you get a set of HIDs, you will need a ballast too. The ballast will regulate the power flow and *should* prevent any bulb out error messages. You can buy canbus-ballasts and canbus-hids, but I have a ballast and HIDs and they work fine.
If your looking for whiter light, you'd need to go towards 5000k as 6000k+ you get the hint of blue.....
I get stuff from HID Direct. No issues so far. X2 ballasts and X2 HIDs. Ideally if you have reflector lenses you'd look to get H7R HIDs as they are designed for the reflector lenses and will pass the MOT. Normal H7 HIDs will of course fit though but may blind people a bit.
I've had no issues at all with my HID in my ownership. Never changed the bulbs yet although I will be soon as one bulb has gone off colour. I am planning to put light tints on the headlights so we'll see how that goes!
« Reply #3 on: January 17, 2013, 09:09:28 pm »
Put a set in mine the other week,but they were didn't have a beam pattern and blinding other drivers so I took them back out,are all the kits like this
Offline Matto
  • -Receive: 116
« Reply #4 on: January 17, 2013, 10:01:30 pm »
It's the headlight that makes the beam pattern not the bulb. Are you running projector headlights or reflector ones?
Offline jonnym
  • -Given: 40
« Reply #5 on: January 17, 2013, 10:05:08 pm »
I think that's where H7Rs will come in if your have reflector headlights. Normal H7s will have a tendancy to dazzle others.
« Reply #6 on: January 17, 2013, 10:05:52 pm »
R
[/qu
Reflector head lights which was might be the problem
« Reply #7 on: January 17, 2013, 10:08:20 pm »
Do the h 7r. Produce a proper beam pattern
Offline Matto
  • -Receive: 116
« Reply #8 on: January 17, 2013, 10:16:35 pm »
I'm not familiar with the H7R's but I know the first time I used hids in the mk4 reflectors they had a tendency to dazzle. Its to do with the light intesity being too much for the reflector to cope with.That's why projectors are used as they are able to focus the light better.
« Last Edit: January 17, 2013, 10:30:18 pm by Matto »
« Reply #9 on: January 17, 2013, 10:24:33 pm »
Cheers Matt think I will stick to my xenon bulbs :signLOL:
Offline jonnym
  • -Given: 40
« Reply #10 on: January 17, 2013, 10:25:13 pm »
H7Rs are something i've only recently come across. From reading up, they have been designed to go into reflector headlights and are designed specifically for them - as such have a proper beam pattern/allignment.
I've copied a qoute from HIDs4U:
""This is a new H7 bulb designed by us and manufactured only for HIDS4U. Many reflector type headlights produce too much glare when fitted with aftermarket Xenon HID systems. With this new H7R bulb you will get a near perfect beam pattern giving a fantastic HID light.
Fits all our HID systems using an H7 type bulb
Fits all reflector type headlights (not suitable for projector type headlights)
So upgrade now from your existing H7 bulbs and take advantage of a this new and unique anti-glare bulb""
Links:
http://www.hids4u.co.uk/h7r-anti-glare-replacement-hid-bulbs.html
http://www.hids-direct.co.uk/categories/hid-xenon-bulbs/hid-bulbs-by-type/h7r
Offline alexperkins
  • -Receive: 99
« Reply #11 on: January 18, 2013, 09:45:01 am »
I have used these before, and they do provide a better beam than normal H7 HIDs
Offline Veee-dubber
« Reply #12 on: January 18, 2013, 09:52:28 am »
HAHA yea wrong section my apologies....
So anyone got any knowledge about the auto light function at all?
I need the whole kit i.e balasts and bulbs rather than just bulbs :)
Offline alexperkins
  • -Receive: 99
« Reply #13 on: January 18, 2013, 09:54:17 am »
HIDS4U do canbus friendly kits with H7R bulbs and ballasts to match.
Offline ConeKiller
« Reply #14 on: January 18, 2013, 09:57:59 am »
I have 8k in my golf H7r without projectors/xenons
The mrs has an eos with xenons as standard with AFL and corner lights. I changed hers for H7 6k hids and the AFL works as normal. If you are only changing the bulb etc  the auto levelling and corner turning will work!
