Author Topic: Michelin Pilot Sport Two (PS2) 225/40/18 92Y Extra Load : Review  (Read 57423 times)
Re: Michelin Pilot Sport (PS2) 225/40/18 92Y Extra Load : Review
« Reply #15 on: October 07, 2009, 12:27:13 pm »
I found the car handled beautifully at 2.6 all round on the exaltos. Too high and it was too hard, too low and it was unresponsive and drank fuel like nothing.
Offline tony_danza
  • -Receive: 112
« Reply #16 on: October 07, 2009, 01:20:23 pm »
See how you get on, it's a trial and error things sometimes, especially with different tyres but something with a stiffer sidewall can genreally take a slightly lower pressure to stop them feeling crashy.
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #17 on: October 07, 2009, 01:22:48 pm »
my car is specified to 2 bar on the fronts, and 2.2 bar on the rears. , and my car is heavier than yours. when i had my sessantas fitted, the garage pumped them up to 2.6 bar, and they were qiuite skittish, but once i droped them, to the factory spec presures it was ok.
imo 2.6 is to high. 2 bar is around 29psi,2.2 bar is 32psi,  2.6 is over 37psi
http://www.tvr-webmart.co.uk/tvr_info_psi.asp
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #18 on: October 07, 2009, 01:56:41 pm »
 :happy2: good advice, 2.6 (37psi) seems on the high side, even for the exaltos  tbh
I run  2.2 (32 psi) all round
let us know how you get on ...
Red ED35 5dr DSG
BLOG | BUILD
« Reply #19 on: October 07, 2009, 02:17:56 pm »
I run around 2.5 - 2.6 as per the guide from VW inside the fuel flap!  :happy2:
Seems good for me for every day use although I went down to about 34psi before I took to the Ring!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #20 on: October 07, 2009, 02:19:09 pm »
are you running PS2's  now then Nathan?
Red ED35 5dr DSG
BLOG | BUILD
« Reply #21 on: October 07, 2009, 09:57:41 pm »
Yokohama Parada Spec 2's at the minute John.
Will be back on the Michelins for the winter as I want the Parada's to last me at least one more Ring Trip!  :happy2:
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #22 on: October 20, 2009, 04:11:37 pm »
2.6 is a little higher than I run and may feel a tad firm???
Try 2.4 F & 2.5R unloaded.
You'll need more in the fronts on a front wheel drive car - especially on the GTI.
On mine with PS2s all round, I run 44psi front, 35psi rear.
  • -Given: 88
  • -Receive: 95
« Reply #23 on: October 20, 2009, 04:13:41 pm »
It is seriously NOT recommended to go below the recommeded pressure - as this can weaken the tyre shoulder, leading to blow-outs.
  • -Given: 88
  • -Receive: 95
« Reply #24 on: October 20, 2009, 04:15:46 pm »
But to compare a TVR with a GTI is like chalk and cheese!  :jumping:
  • -Given: 88
  • -Receive: 95
« Reply #25 on: October 20, 2009, 04:17:09 pm »
No - NEVER run below the manufacturers recommeded setting -which is 35psi front, and 35psi rear!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #26 on: October 20, 2009, 07:28:37 pm »
44 psi TT  :surprised:
may have to try that you crazy fool  :stupid: :drinking:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #27 on: October 20, 2009, 09:00:06 pm »
Inside my fuel flap says 2.6 bar front and rear, fully loaded 2.8 and 3.2!  :surprised:
Hence I run at around 38 - 40psi.
Offline tony_danza
  • -Receive: 112
« Reply #28 on: October 20, 2009, 09:26:01 pm »
I disagree.
For one, my old 150PD Anniversary MKIV's recommended pressure was 32PSI - factory supplied with 18" wheels and PSs, so the sticker in the fuel flap was for that wheel/tyre spec. I wouldn't say my MKV was significantly heavier (in fact, I think it is lighter), so my pressures are well within the tyre's range.
Also, the fronts heat up, and therefore increase in pressure much more than the rears. This evens things out. You don't want a greasy, understeery front end and loads of grip on the rear, well unless you're de-GTIing the GTI.
Finally I think running 44PSI is dangerous and I'm surprised you're recommending it. On a spirited drive I can see my pressures come up by around 4-6PSI depending on the weather, by that same reckoning, you'd be near or at the maximum limit of 50PSI and serious risk of tyre failure.
« Last Edit: October 21, 2009, 09:37:23 am by tony_danza »
Sideways yo!
  • -Given: 88
  • -Receive: 95
« Reply #29 on: October 22, 2009, 01:56:51 pm »
TBH, it isn't actually far off the fully loaded pressure anyway!
