Author Topic: Wheel Fitment Guide  (Read 4067 times)
Offline The wheel man
Wheel Fitment Guide
« on: July 09, 2009, 12:22:26 pm »
As there seem to be loads of posts about that will and wont fit on the GTI i though it could be a good idea to have some sort of wheel fitments guide.  This is where you guys come in!!  What i need is the size, width and offset  of the wheels your running, tyre size and ammount lowered (if at all)  Any issues with rubbing would also be usefull.  What i can then do is work out the minimum and maxumun clearance for each diameter / width to give an easy guide IE
18x8       Offset range 40 to 50 - Tyresize 225/40/18.  Upto 40mm lower no rubbing
18x8.5    Offset range 45 to 50 - Tyresize 225 or 235/40/18 Upto 30mm lowering no rubiing with arch bolts removed.
What do you think?
Ben
APR cat back, ECS Insert
Offline Mark_GTIV
Re: Wheel Fitment Guide
« Reply #1 on: July 09, 2009, 01:21:41 pm »
18x8 ET 50 with 8mm spacers and 225 40 18 tyre lowered 30mm - No rubbing but had to do inner arch mod.
« Reply #2 on: July 09, 2009, 02:31:32 pm »
19 x 8 ET 50 - lowered 40mm 235/35/19 tyres - no rubbing but had to do screw removal mod
« Reply #3 on: July 09, 2009, 07:02:03 pm »
very soon to be 19x 8.5 ET 45 slammed with camber adjustment. tyres 235/35/19  :smiley:
Offline candy turbo
« Reply #4 on: July 09, 2009, 08:48:35 pm »
if you used 225/35/19 should have had no probs !!! so i been told  :happy2:
« Reply #5 on: July 10, 2009, 07:49:04 am »
Thanks guys
Keep em coming though... the more fitments i get the better  :happy2:
Offline illyun
« Reply #6 on: July 10, 2009, 09:47:06 am »
Great post wheelman... :jumpmove:  will this be compiled into a chart or something?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #7 on: July 10, 2009, 09:52:12 am »
Yes I will create a table to go into the FAQ's section for this  :happy2:
« Reply #8 on: July 10, 2009, 09:54:18 am »
18 x 8  ET45 - lowered approx 30 mm on 225/40 rubber - no rubbing , but have already done screw mod.
Offline tony_danza
  • -Receive: 112
« Reply #9 on: July 10, 2009, 10:08:40 am »
18x8 ET 42 225/40/18 - couldn't tell you how far it's lowered, but there's approx 15mm between tyre and arch.
Screw mod done, have pulled the arches on both sides and had to fold them back. Big holes in arch liners from rubbing under compression all the way up Foxhole at XXXmph.
Rears are fine though.
Sideways yo!
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #10 on: July 10, 2009, 11:37:32 am »
18 x 8.5 225/40/18 (not sure on the et) slammed 65mm, lots of rubbing before arch's were rolled.
Offline pazz
« Reply #11 on: July 10, 2009, 01:21:41 pm »
You mean something like this (taken from GolfMKV.com):
http://i200.photobucket.com/albums/aa1/RabidRabbit33/untitled-1.jpg
If the offset isnt listed (generally ET32 or less) then its not recomended with stock arch's.
And roughly speaking (dont ask why they use inch's!):
1" = 25mm
1.5" = 40mm
2" = 50mm
Offline gazbutS3
« Reply #12 on: July 10, 2009, 01:24:01 pm »
On my Ed30, 8X19 ET50, 235/35/19 Toyo, lowered 25mm on coilovers, front arch screw mod, no rubbing :happy2:
Offline joesgti
« Reply #13 on: July 10, 2009, 02:07:54 pm »
yours was lower than 25mm!!  :confused:
Offline gazbutS3
« Reply #14 on: July 10, 2009, 02:57:23 pm »
it was a while ago :smiley:
