September 24, 2024, 10:19:20 am
All Things Mk5
Mk5 General Area
Struggling with gears? :/
Topic: Struggling with gears? :/ (Read 1396 times)
James5763
Taking part
-Given: 0
-Receive: 0
January 22, 2013, 05:38:16 pm »
Hi I've noticed that sometimes I'm struggling getting it in and out of gear and also when on flat surface I can be in 1st with clutch all the way down and it's still biting and taking me forward, any ideas? Thanks 2.0 tdi gt
Dubbin
Just Arrived
-Given: 0
-Receive: 1
Re: Struggling with gears? :/
Reply #1 on:
January 22, 2013, 06:40:56 pm »
Seems that your clutch is dragging. Assuming it is a hydraulic clutch I would try bleeding the slave cylinder. If cable clutch try adjusting it.
GTI, DSG, Xenons, Laser Blue, Sunroof, 5 Door, Monza IIs, MFSW
James5763
Taking part
-Given: 0
-Receive: 0
Reply #2 on:
January 23, 2013, 10:18:33 am »
Any idea how to bleed?
James5763
Taking part
-Given: 0
-Receive: 0
Reply #3 on:
January 26, 2013, 01:01:46 pm »
New clutch needed apparently ;(
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #4 on:
January 26, 2013, 08:59:02 pm »
Quote from: James5763 on January 26, 2013, 01:01:46 pm
who told you that, a VW dealer?
James5763
Taking part
-Given: 0
-Receive: 0
Reply #5 on:
January 26, 2013, 09:38:41 pm »
No a local mechanic, I don't see how it's a new clutch when it's biting more then slipping..... Also was told by another mechanic to bleed the clutch, I have no idea to be frank
vRSAlex
Admin
Just look at my post count
-Given: 39
-Receive: 253
My Ride:
Reply #6 on:
January 26, 2013, 09:46:41 pm »
Does the pedal feel normal? Any play at the start kf the travel?
Build Thread
www.akstuning.co.uk
- info@akstuning.com - 01234 822324
Follow AKS tuning on
Facebook
James5763
Taking part
-Given: 0
-Receive: 0
Reply #7 on:
January 26, 2013, 10:23:47 pm »
Peddle feels fine, car sets off quick as its already on bite and the last 3-4 of travel on the way up don't do anything on the clutch
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #8 on:
January 26, 2013, 10:36:13 pm »
You on high miles? Sounds like the cluch friction plate has worn out and the cover plate is at full adjustment.
Build Thread
www.akstuning.co.uk
Facebook
James5763
Taking part
-Given: 0
-Receive: 0
Reply #9 on:
January 27, 2013, 09:50:25 am »
I'm at 125k with a gt tdi, had a flywheel and clutch put in 4k ago but these had done 60k I believe, this was when I first bought the car
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #10 on:
January 27, 2013, 10:45:57 am »
Seems odd to put a 60k used clutch in a car. Only around 200 for a brand new clutch kit.
Was the cover plate that was fitted adjusted back to original 'new' settings with a special tool or just chucked in?
Build Thread
www.akstuning.co.uk
Facebook
James5763
Taking part
-Given: 0
-Receive: 0
Reply #11 on:
January 27, 2013, 12:54:35 pm »
I believe it was flywheel and clutch that was done as the fly wheel was beyond gone, I couldn't tell you, my guess would be chucked in
James5763
Taking part
-Given: 0
-Receive: 0
Reply #12 on:
January 27, 2013, 01:21:34 pm »
Just been told its a self adjusting clutch
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #13 on:
January 27, 2013, 01:27:11 pm »
Quote from: James5763 on January 27, 2013, 01:21:34 pm
Yes. When it reaches full adjustment then it cant release the cover. If a used one is refitted then it needs adjusting back to original new adjustment.
Build Thread
www.akstuning.co.uk
Facebook
All Things Mk5
Mk5 General Area
