Author Topic: Considering stepping back from stg 2+ to stg 2 options...  (Read 870 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: January 23, 2013, 09:59:10 pm »
Am considering the above with longetivity and reliability in mind. Stg 2+ is awesome but as a few wise old sages have said it is bordering on being a step too far if you want to run the car to high mileage. I may keep the Eddie for another 5 years at this rate.
if i do step back cant decide which of these options makes the most sense
1,) alter map and put milder settings than 9/6//6 on (along the lines of Robin's settings boost 7....) and leave the HPFP on because it will still be of some benefit of Stg 2?
2.) alter map, ditch the HPFP and possibly the CAI and run engine cover with performance panel filter, tbe and s3 intercooler. does anyone know if the HPFP comes off can you leave the RS4 valve in cause is PITA to change? If the HPFP comes off and the F setting goes leaner can I still potentially run high timing (Currently 6) if the Twintercooler stays on the car?
If i go for option 2 what would be the likely range of power/torque drop bearing in mind currently running 361bhp and 348lb ft in percentage terms?
Thanks in advance for thoughts/opinions
Offline gazbutS3
Re: Considering stepping back from stg 2+ to stg 2 options...
« Reply #1 on: January 23, 2013, 10:04:38 pm »
I ran stg2+ with the std airbox on 6/6/9 for a few months and it made it a really flexible road car, often wonder if that is my ideal set-up, I reckon stg 2 and the pump and airbox would be good too :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: January 23, 2013, 10:16:08 pm »
yeah suppose could just alter revo settings with a stg 2 map and leave all the hardware on, although having seen gazon's cam follower thread would consider ditching the hpfp. in two minds at minute hence post.
« Reply #3 on: January 23, 2013, 10:22:00 pm »
....But bear in mind I'm running a K03 GTI, not a K04 Ed30.
Aftermarket HPFP will still benefit you by maintaining fuelling 'headroom' and keeping that sweet on demand.
Offline gazbutS3
« Reply #4 on: January 23, 2013, 10:24:59 pm »
can understand your concerns mate, but I've been running the APR pump for 25kish now and change my follower every 10K (5K oil changes) and have never seen any abnormal wear, infact I'd have been happy to put the old one back in but because I had a new one there, change it
this is with a few trackdays, sprints etc included
