Author Topic: Removal of windscreen washer nozzles  (Read 2610 times)
Offline andygjc
« on: January 24, 2013, 11:22:37 pm »
Hi all,
Feel a bit stoopid asking this but one of my washer nozzles has started to only work at "half potential" I want to disconnect it from the hose pipe to try clean it out with air or a soak! Is there a particular nack to doing it? When I try pull it off it feels like it'll brake! Any suggestions?
Offline doylebros
Re: Removal of windscreen washer nozzles
« Reply #1 on: January 25, 2013, 05:06:47 pm »
Offline andygjc
« Reply #2 on: January 25, 2013, 05:24:25 pm »
Thanks for that, I think this is to remove the nozzle from the bonnet though? I cant seem to get the pipe off the nozzle! Thanks though!
Offline doylebros
« Reply #3 on: January 25, 2013, 05:45:19 pm »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: January 25, 2013, 05:50:05 pm »
Then soak in warm water.
I had to unclog my rear washer one time. I wandered around the kitchen blowing through it really hard. My face went purple and I was called a retard by a family member.
It worked though so sometimes the retards are rewarded.
'07 Red manual
Offline OSB
  • -Given: 32
« Reply #5 on: January 27, 2013, 04:25:03 pm »
A blast through with a compressor will usually do it.
I don't know what the fitting is like on a Golf, but I have also jammed the end of a foot pump on other cars in the past.
Offline andygjc
« Reply #6 on: February 10, 2013, 05:59:21 pm »
Sorry only giving an update about what I meant with regard to the fitting! When you pop the nozzle out of the bonnet, to get the pipe off there is a collar that needs to be twisted in order to release the pipe. This is what I was having trouble with.
I tool it off and soaked in warm water for a while, Also blasted through with a compressor but it is still the same! Looks like it needs a replacement nozzle!
