Author Topic: Misfire on a tfsi not plugs or coils  (Read 12540 times)
Lee M
« on: January 26, 2013, 04:52:43 pm »
Hi all.
2.0 tfsi cupra:
I have a misfire on cylinder 2. Mainly on idle or low speeds and more noticeable  after its warmed up.
I have replaced plugs  this morning as I though it was that. My last set died at 15k and I've done about that since then. New plugs are up rated/colder iridium NGk as I'm running 2+.
Tried swapping coil packs between cylinders and that made no difference either, fault stays on cylinder 2.
Monitoring the misfire counter using VCDS it counts about 60-80 misfires in about 2 mins.
Am i looking at an injector fault as the next thing to look at?  If so where are they located?
Cheers. Lee
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Misfire on a tfsi not plugs or coils
« Reply #1 on: January 26, 2013, 05:02:17 pm »
If yours is a K03 engine, I'm selling an injector for £13 posted  :happy2:
Offline chungster
« Reply #2 on: January 26, 2013, 05:07:22 pm »
Had this prob on cylinder 1 recently. Injector was at fault.
PITA job though as its intake manifold off job as injectors are under that!
Lee M
« Reply #3 on: January 26, 2013, 06:39:05 pm »
Hi mate. Unfortunately not. It's a ko4 cupra. Cheers though.
Lee M
« Reply #4 on: January 26, 2013, 06:40:15 pm »
That's where I thought they were from what I could make out. What a sh1tter. Is it doable DIY or did you get a garage to do it?
Offline chungster
« Reply #5 on: January 26, 2013, 07:41:12 pm »
Had Alex @ AKS do mine - no way would i attempt it myself! I watched him put the manifold back on and getting it all lined up with the long studs is a PITA it seems! PM him if you want an estimate for supply and fit if you're near bedfordshire :happy2:
While that's off you may want to add the RS4 FPR  :wink:
« Last Edit: January 26, 2013, 07:42:59 pm by chungster »
Offline pd9264
« Reply #6 on: January 26, 2013, 07:49:05 pm »
im in the same boat. got a serious misfire on cylinder 4. AKS changed plugs and coil packs to see if it cured the problem. but he nailed it down to a faulty injector. they ent cheap though about 150-160 + vat for one. i fitted them myself and they are a pain to do.
Lee M
« Reply #7 on: January 27, 2013, 12:06:49 pm »
Cheers mate. Sounds like a mission but I guess I have no choice. I've done all the easy checks and changes.
Did you change all 4 or just the faulty one?
Offline pd9264
« Reply #8 on: January 27, 2013, 07:06:23 pm »
in going to just change the faulty one. should be fine
Lee M
« Reply #9 on: January 30, 2013, 11:23:34 pm »
Ok all. I'm just listing out bits I need to give the injector replacement a go. I'm going to clean the valves too If they need doing whilst its off.
Any pointers or things to consider replacing/checking whilst manifold is off?
I'm going to get:
New intake manifold rubber gasket
Blue Injector seals for the other 3 injectors (injector to fuel rail)
Rs4 valve? Whilst its off
Anything I've missed?
Lee M
« Reply #10 on: February 01, 2013, 02:08:21 pm »
I can't buy the injector blue seals separately, that fit into fuel rail.  I'm presuming its ok to re use the ones in the injectors I'm not removing?
Offline vRSAlex
  • -Receive: 253
« Reply #11 on: February 01, 2013, 02:17:22 pm »
You need to buy a 'repair' kit part number 06D 998 907
Follow AKS tuning on Facebook
Lee M
« Reply #12 on: February 02, 2013, 02:38:09 pm »
Thanks mate. I've got them ordered. :-)
« Reply #13 on: February 02, 2013, 06:40:58 pm »
Quote from: Lee M link=topic=60448.msg682185#msg682185
Quote
How much are they charging you as I'm pretty sure I have a set somewhere?
Offline ttdan
« Reply #14 on: February 02, 2013, 06:49:38 pm »
Had an idle misfire on my ed30, cyl 4, was a bad injector at 44k miles, vw did it for 2 hours lab + parts, + 30 mins diagnosis time, not terrible I thought.  But disappointing on a low ish mile engine.
