Author Topic: Bluefin has immobilised my car!  (Read 4539 times)
Offline Baz300
« on: January 27, 2013, 09:27:40 am »
I am in at work today and thought I would reload the stage 2 map onto my car during my break.
The process seemed to go ok but halfway through the installation the bluefin unit beeped twice and I got an error stating that the car is immobilised.
Now my car won't start.
I tried to see if I could reinstall the bluefin again and I get a warning saying
" please insert to car that was originally used"
I tried disconnecting the battery for 30 mins to see if it would un immobilise itself but there is no difference.
Has this happend to anyone else? How can it be solved?
Otherwise my car is stuck at work and ill have to get a taxi home and back to work tomorrow.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Bluefin has immobilised my car!
« Reply #1 on: January 27, 2013, 09:28:54 am »
I'd get on the phone to Superchips pronto mate  :sad1:
Offline Baz300
« Reply #2 on: January 27, 2013, 09:40:34 am »
They are not open untill 9am tomorrow
Already tried to call
Offline donovan2123
« Reply #3 on: January 27, 2013, 09:49:50 am »
Have you tried to load original file back onto car from bluefin?
Offline donovan2123
« Reply #4 on: January 27, 2013, 09:54:42 am »
Also double check battery voltage is over 12v ideally 13-14v maybe jump leads to a car that's running
« Reply #5 on: January 27, 2013, 10:00:13 am »
the battery should be 12v and when its running will be 13-14v
Offline Baz300
« Reply #6 on: January 27, 2013, 10:02:05 am »
The bluefin won't let me do anything as it thinks it is connected to a different car now.
Voltage is 12.4v at the battery
Offline donovan2123
« Reply #7 on: January 27, 2013, 10:05:31 am »
Oh bad times is there software on a computer or anything than can reset bluefin as you have maps
Saintsteve
« Reply #8 on: January 27, 2013, 10:07:58 am »
Hate to say but your car won't go anywhere till Superchips resend your stock file .monday morning fella.
« Reply #9 on: January 27, 2013, 10:09:37 am »
sure i have read  problems similar with blue fin on here
Saintsteve
« Reply #10 on: January 27, 2013, 10:12:26 am »
Mine did this my accidentally turning off the ignition whilst in mid file transfer.(my error) never had an issue in several years
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #11 on: January 27, 2013, 10:14:42 am »
The low battery sounds feasible on either car or bluefin, try and get both topped up and try returning to the standard map, iirc bluefin doesn't wipe the map, just relocates.
Offline Baz300
« Reply #12 on: January 27, 2013, 10:16:54 am »
This is the first issue I have had with it.
I removed the map for my MOT as I read reports of it running a bit rich and failing on emissions.
Just tried to reinstall the stage 2 today as the snow was starting to clear.
They do have another stage 2 map ready for me to download (uprated hpfp) so will try and download that when I get home and try again when I'm back at work tomorrow morning (start at 6am)
If that doesn't work I will have to phone superchips and hopefully they can help
« Reply #13 on: January 27, 2013, 10:18:16 am »
could some one with vag com get it started
Offline donovan2123
« Reply #14 on: January 27, 2013, 10:20:32 am »
No vagcom won't starting it.
