Author Topic: Painting the inside of my Monza wheels .. and Hubs  (Read 2119 times)
Offline OSB
  • -Given: 32
« on: January 27, 2013, 05:10:43 pm »
I'm thinking of painting the inside of my wheels. The outsides are in v good condition but the accumilation of dust and grime shows throgh the holes.
I don't want to go to the trouble and expense of having them sprayed as I'm not after a 'show car' But I want them to look nice!
So I am considering using Hammerite Special Metal Primer (except that its only available in red!) followed by or just using Hammerite Smoothright Silver. I recon I can brush paint neatly enough.
Any thoughts?
I also want to paint the exposed parts of the hubs.
I could use cans of spray for them, but a coat of Hammerite would be quicker!
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Painting the inside of my Monza wheels .. and Hubs
« Reply #1 on: January 27, 2013, 05:15:53 pm »
This will be nails to achieve a good finish.  You'll definitely have to mask off like a feckin' master masker then allow for 2 hours a wheel to get right if hand painting... better to spray and lacquer. Good luck though dude, post results:)
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #2 on: January 28, 2013, 07:43:01 am »
You'll waste so much time, just get it refurbed professionally. Then take care of them properly once it's done.
#1493
Offline OSB
  • -Given: 32
« Reply #3 on: January 28, 2013, 09:51:01 am »
Thanks guys - you are prob right!
It costs £70 per wheel round here and I was just trying to avoid £280..........
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: February 02, 2013, 09:17:38 am »
Am I reading this right? You want to paint the insides because they are dirty? Would it not be a lot cheaper and easier to take the wheels off and clean them?  :confused:
Offline OSB
  • -Given: 32
« Reply #5 on: February 02, 2013, 10:15:45 am »
My bad use of english.... or poor description....
The surface of the inside of the wheels - 3 of them - is rough, and the dirt, brake dust and grime accumalates quite quickly. I notice this through the holes in the Monza wheels - call me OCD!
Even a blast with a jet wash does not really clean them up.
On a previous car the wheels were painted/sprayed on the inside, leaving a smooth finish and the muck came off much easier.
Its not a 'show and shin'e car but it is pretty tidy and it just irritates me!
Offline Kalpsn2000
  • -Receive: 56
« Reply #6 on: February 02, 2013, 02:17:21 pm »
Ah in that case you may need to have them referbed. Have you taken any of the wheels off to actually see if they are corroded?
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #7 on: February 10, 2013, 10:42:44 pm »
I used halfords high temperature black paint on my hubs. Good stuff  :happy2:
Offline Eccie
  • -Receive: 25
« Reply #8 on: February 11, 2013, 09:37:30 am »
You need to get them off the car and clean them properly, you may just find the roughness is an accumulation of brake dust & tar.
Wash them, IronX them twice, clean them with Tardis or such a couple or three times, then you'll know what your dealing with, looking through the holes in the wheels will only give you a rough idea as to the state of them.
And when you've done all that, if your happy with them polish & seal them, before they go back on the car, thatll help to keep them clean & smooth
Offline OSB
  • -Given: 32
« Reply #9 on: February 11, 2013, 09:47:29 am »
Thanks Eccie. I like your quote about eye candy!
As soon as the weather gets warmer I'll give the 'through cleaning' a go - but can you explain  your bit about - IronX them twice, clean them with Tardis or such a couple or three times ....
Not sure what those products are / do.
Offline Eccie
  • -Receive: 25
« Reply #10 on: February 11, 2013, 09:58:40 am »
Seek and ye shall find - its all out there, just use the search on here or google
http://www.mk5golfgti.co.uk/forum/index.php/topic,44827.0.html
http://www.mk5golfgti.co.uk/forum/index.php/topic,37839.0.html
Offline OSB
  • -Given: 32
« Reply #11 on: February 11, 2013, 04:07:43 pm »
I sought and found! Thanks for the info. Appreciated. I'll post how I get on - when the weather is a bit warmer .........
