Author Topic: Knocking noise coming from rear Please help!!  (Read 2591 times)
Offline DanielF
« on: January 29, 2013, 10:08:02 pm »
Hello people
I've got a golf mk5 tdi and it's recently started to make a knocking noise at the rear I have replaced the anti roll bar bushes and drop links but it is still the same.
The noise gets worse over lots of bumps I would say the noise is like plastic knocking.
I am also lowered on fk silver line coilovers which was fitted about 1month ago.
If anyone could give me some info I would be very grateful.
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Knocking noise coming from rear Please help!!
« Reply #1 on: January 29, 2013, 10:25:31 pm »
everything out of the boot, spare wheel etc, Seats down and up, parcel shelf out, wheel arch liners
Offline DanielF
« Reply #2 on: January 29, 2013, 10:26:45 pm »
Tried all of that and still does it :( defiantly coming from under the car.
Offline camfollower
  • -Receive: 31
« Reply #3 on: January 29, 2013, 10:29:32 pm »
Exhaust?
Definitely not rubbing then.
Dead shock due to lowering too much.?
Offline webby888
« Reply #4 on: January 29, 2013, 10:34:32 pm »
iv got the same issue with mine with fk street coilovers
Offline DanielF
« Reply #5 on: January 29, 2013, 10:35:10 pm »
Not exhaust mate
But could be rear shocks but there only a month old :(
Offline DanielF
« Reply #6 on: January 29, 2013, 10:36:07 pm »
Is yours like a plastic rattle and does it do it a lot over slight bumpy roads?
Offline webby888
« Reply #7 on: January 30, 2013, 05:25:02 pm »
yeah exactly that! higher speeds cant hear it too much tho just slow speeds on small bumped roads
Offline DanielF
« Reply #8 on: January 30, 2013, 06:53:38 pm »
Not good at all :( some must of solved this problem
What have you tried so far?
Offline OSB
  • -Given: 32
« Reply #9 on: January 30, 2013, 07:14:45 pm »
I had 2 tapping noises from the rear -
1 was suprisingly loud for a small item - one of the rear number plate lights was loose. Tightened the screws but it did not stop and found a sealing gasket was missing.
The other was a wire loose (leading to my rear parking sensors) behind the R/H side boot trim. Trim is a bit of a sod to get off, so I got the rear free enough to jam some foam in, on the wire. Waiting for warmer weather to do a proper job.
Hope these might help.
Offline OSB
  • -Given: 32
« Reply #10 on: January 30, 2013, 07:19:42 pm »
And on a previous car I found the number plate rattled. Tightened the screws but the centre of the plate would flap slightly so I stuck it down with double sided foam pads...
Offline DanielF
« Reply #11 on: February 02, 2013, 08:40:16 pm »
Anymore ideas people?
On the rear suspension setup I've got a rubber at the top and then put the adjuster at the bottom but didnt put no rubber under it is this right?
