Author Topic: Got Sachs clutch installed...  (Read 10565 times)
Offline golfman
  • -Given: 17
Re: Got Sachs clutch installed...
« Reply #15 on: December 21, 2009, 09:26:43 pm »
I love my sachs clutch  :stupid: :stupid:
i totally agree with the biteing point it's nuts,the car just takes off :evilgrin: :evilgrin:
mine vibrates but i don't get a rattle :confused:
the clutch peddle is a lot harder but you do get used to it :driver: :driver:
golfman
Vag-com Hex+Can in scotland
I Hate Timewasters...
« Reply #16 on: December 22, 2009, 02:03:52 pm »
@Perskarik : good to hear  :happy2: , dont forget a new clutch beds in so dont beat it too much early on
@all : anyone got part numbers to go with these items? Im sure sachs make more than one mk5 clutch  :innocent:
@tfsimike : wouldnt worry mine makes similar dodgy noises (albeit stg1 not 2+) and has so from new :confused:
Mine's in the boot so will get you the part number tonight smiler!  :wink: :happy2:
« Reply #17 on: December 22, 2009, 03:26:03 pm »
Here you go bud!  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #18 on: December 22, 2009, 07:50:13 pm »
cheers Nath :happy2:
shame about the fishnets  :xmaspresent:
Red ED35 5dr DSG
BLOG | BUILD
Offline Blade
  • Taking a sabatical from cars
« Reply #19 on: December 22, 2009, 08:35:46 pm »
Got my Sachs organic jobbie fitted last week. As said, the pedal has a heavier feel but i like that. No juddering or noises coming from mine.
« Reply #20 on: December 22, 2009, 08:41:25 pm »
My pedal feels very high with my sachs clutch plate.  Had the plate and new DMF not yet had the pressure plate fitted.
Offline Blade
« Reply #21 on: December 22, 2009, 08:47:24 pm »
Mike, my pedal engages lower than it did with o/e. Didn,t need a flywheel as mine was inspected and appeared in good nick.
Offline chungster
« Reply #22 on: December 22, 2009, 08:57:45 pm »
i thought you had to have both cover plate and pressure plate fitted at same time?
I did anyway...but stuck with the OEM flywheel.
It sure does feel "racy" anyway...as in you want to change gears even quicker! Bite is certainly a lot more aggressive.
Offline Blade
« Reply #23 on: December 22, 2009, 09:06:07 pm »
Its b***ox about having to change the flywheel - money making propaganda springs to mind - obviousley some are knackered but not to the extent dealers would have you believe i think.
Offline chungster
« Reply #24 on: December 22, 2009, 09:15:34 pm »
AmD didn't even ask me about the flywheel actually! They just offered the cover/pressure plates. But they do normally ask about the cars mileage before advising if the flywheel should be done also.
« Reply #25 on: December 23, 2009, 06:54:26 pm »
Sam @ VWR showed me mine and it was buggered, alot of movent in it :(
Offline Blade
« Reply #26 on: December 23, 2009, 07:56:48 pm »
you sure it was Mike. The flywheel should will rotate left to right a few cm,s - doesn,t mean its knackered but a lot of people think that means it is.
Offline billyboy
  • Billy lar
« Reply #27 on: December 23, 2009, 08:13:03 pm »
Ive seen somewhere, that you move it one way then the other, and take a measure of the play (which should be there)
to detirmine if its FooKeD
billy
« Reply #28 on: December 23, 2009, 08:16:58 pm »
Dont know the serviceable limit of movement or even the actual amount of movement on my flywheel.
When showed and advised to me it was fubared I was inclined to believe what I was been told.  Any of the tuners I use have much more experience with the Tfsi than me.
Really wish I didnt have to shell out nearly 500 on a new flywheel cause Id have a diff now :(
Offline david_phillips95
« Reply #29 on: January 27, 2010, 06:38:01 pm »
i have recently had my sachs performance clutch installed, it has not covered any miles since install. on the first test drive it judders in 1st and reverse but once its moving its fine through the gears. have most of you guys experienced this or does it sound abnormal??
Cheers Davie
