Author Topic: Exhaust Pre-Cat bolts  (Read 3508 times)
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« on: January 31, 2013, 06:23:36 pm »
I've had a good look around but can't find part numbers for these, can anyone help me out?
It's the 4 bolts that mate the Downpipe to the Turbo manifold.
Offline Baz300
Re: Exhaust Pre-Cat bolts
« Reply #1 on: January 31, 2013, 06:26:27 pm »
N10286108 £3.22 for 4  :happy2:
Offline camfollower
  • -Receive: 31
« Reply #2 on: January 31, 2013, 06:27:46 pm »
Awesome Baz, cheers! :happy2:
Edit: These seem to be nuts.  Mine are bolts. :sad1:  Perhaps things were changed, mine's an a 2005 model.
« Last Edit: January 31, 2013, 06:31:20 pm by camfollower »
Offline Baz300
« Reply #3 on: January 31, 2013, 06:42:02 pm »
The turbo has the studs already attached to it.
It will still have the nuts that you need to remove to get the downpipe off.
Offline camfollower
  • -Receive: 31
« Reply #4 on: January 31, 2013, 08:09:09 pm »
What the hell am I on about then!? :grin:  Sorry Baz, I must be tired. :indifferent: of course your right, I'm after the Exhaust carrier flange thing bolts, it has two rubber bungs that have two carrier rods above...
This guy is locating one here...
Any ideas what the P/N for they are mate?
Cheers bud. :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #5 on: January 31, 2013, 08:13:03 pm »
The part numbers were in my Pre cat. . . Removed thread mate  :grin:
Offline Baz300
« Reply #6 on: January 31, 2013, 08:13:17 pm »
That's an exhaust to subframe mount.
I got new bolts when I bought the mount from VW
Unless you are on about the flange that's connecting the 2 parts of that exhaust together? That isn't a Standard exhaust in that pic, the standard one does not split like that it is one piece from the turbo till the middle of the car.
Offline camfollower
  • -Receive: 31
« Reply #7 on: January 31, 2013, 08:18:42 pm »
Thanks. Yeah it's the mount one he's screwing in above.  I found a bolt of similar dimnesions one on my driveway (recently had exhaust done), but feckin' miss placed it. :rolleye:
Offline Baz300
« Reply #8 on: January 31, 2013, 08:22:00 pm »
Just show that pic to VW or TPS and I'm sure they will be able to get the bolts orderd for you.
