Author Topic: Intercooler Inlet Hose  (Read 1609 times)
Offline GTI5
« on: January 31, 2013, 08:02:21 pm »
Hey Guys
I have a leak coming from a connection (Drivers side Intercooler hose) and its probably the seal...
Whats the score with removing and installing the metal clips? Are they reusable?
Thanks in advance.
MK6 GTI Revo
MK5 GTI DSG - Gone
Re: Intercooler Inlet Hose
« Reply #1 on: January 31, 2013, 08:32:54 pm »
Yup, clips are reusable...
Offline GTI5
« Reply #2 on: January 31, 2013, 09:02:11 pm »
Thanks - Is it a screw driver job to lift the clip or is there something that needs pressing in to release?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: January 31, 2013, 09:44:27 pm »
Sorry to butt in but doesn;t anyone have the part number for the seal and know the size of the s3 intercooler pipes?
Diesel Daily Hack.
« Reply #4 on: January 31, 2013, 10:17:33 pm »
I just used a screwdriver to get mine out. I suspect your problem is a perished O ring that you can get from your dealer. For the gti this pic is valid.
Offline GTI5
« Reply #5 on: February 01, 2013, 07:20:20 pm »
Thanks Dude :happy2:
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Jbrist
« Reply #6 on: February 17, 2013, 07:45:25 pm »
Hi,
Did you manage to fix this? As mine is also leaking.
Also did you have any whistling noises?
Offline GTI5
« Reply #7 on: February 18, 2013, 06:19:57 pm »
Hi,
Hi
Yes I replaced it, I also bought a new clip for the pipe but the one I had was ok so I reused it.
The seal I removed was in better condition than I had thought it would be. I removed the pipe and there was very little residue left, so it must have been leaking much more some time ago. I put this down to changing the PCV to the latest revision a while back.
If you are going to do this yourself I would suggest you do not remove the clip completely from the pipe unless it is rusty/broken...I did this and it added time to the job as you can't see one side of the pipe where the clip slots in.
Do you mean whistling noises from this particular connection?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline Broomy
  • -Given: 18
« Reply #8 on: September 18, 2014, 10:57:10 pm »
Same problem here, how are the clips removed without taking them off the pipe? Anyone know the part number for the other side o-ring?
