Author Topic: Fiscon basic plus bluetooth issue  (Read 1135 times)
Offline wattso
« on: February 02, 2013, 05:11:20 pm »
Hi all,
Would be really grateful if someone could help me with my issue, I've spent hours pulling my hair out now.
I think the factory hands free kit is causing the issue ( the annoying one that has the dashmounted phone holder ) But I could be wrong
So when I make calls through bluetooth or use bluetooth music streaming the blutooth will cut off every few seconds and is generally sketchy, at which point the music from the fns HDD will resume playing, presumably since it thinks there's no bluetooth connection anymore so resume what was happening.
I initially assumed that the fault was down to a lose cable and a simple re jiggle would suffice.
However I've had a look on fiscons website and I think it's due to my telephone prep kit that is installed:
Quote
Q:The voice is interrupded, the radio is blinking.
A: If you have a OEM handsfree installed at the same time you need to remove the fuse or connector of the phone interface. Otherwise the old handsfree can disturb the communication.
So I looked to remove the fuse for the unit... first of all it's not clear on any fuse diagram, secondly when I did see reference to a telephone in the fuse diag it was in slot 48 - which is unused. So I removed fuse 49 in the interest of science and what happened was strange, the bluetooth still worked with the same fault however music streaming would just not work?
So I've located and removed the BT module ( I think.... picture attached to ensure I've disconnected the right thing )
However it hasn't solved the problem ... The voice and streaming music still cut out.
I've got my hands on a vagcom and when going into 77 - Telephone prep I get error "Too many communication errors occurred"
Would be really really grateful if anyone can help at all. I've had it half working for too long now and just want it sorted.
Here's a video of how vcds behaves when trying to go into Telephone.
Don't think they're related... but other vagcom errors that I had are below. Although could be related as it seems to be the 'Radio' rns510 that is cutting into the bluetooth feed for half a second to play the radio audio output.
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H03 2720
   Revision: AB001001    Serial number: VWZ6Z7H5305034
   Coding: 040004000400008200
   Shop #: WSC 01357 011 00200
   ASAM Dataset: ------------------------- ------
   VCID: 2E554B7B79C7BC68830
2 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 184
                    Mileage: 194360 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:27:22
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 194365 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:27:23
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 184
                    Mileage: 194360 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:27:22
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 194365 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:27:23
Many thanks in advance.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Fiscon basic plus bluetooth issue
« Reply #1 on: February 09, 2013, 11:12:19 pm »
Free bump for you WATTO :)
