Author Topic: Springs  (Read 9737 times)
Offline MickMc
Springs
« on: November 26, 2008, 08:33:06 pm »
Was just about to order some spax springs and it says "For cars with 55mm struts only" how would i find this out  :laugh:
also will a 45mm drop be ok with 19s  :happy2:
Re: Springs
« Reply #1 on: November 26, 2008, 08:38:16 pm »
h&r springs seem to be the favoured springs. the drop with those and 19s is supposed to be bees knees!!
Re: Springs
« Reply #2 on: November 26, 2008, 08:40:45 pm »
afaik all the gtis have a strut diameter of 55mm.
Offline MickMc
Re: Springs
« Reply #3 on: November 26, 2008, 09:21:46 pm »
Hmm , i clicked the link for the 2.0 tdi ones and it says that
Offline MickMc
Re: Springs
« Reply #4 on: November 26, 2008, 09:58:20 pm »
Re: Springs
« Reply #5 on: November 26, 2008, 10:55:51 pm »
What model golf do you have as the springs will differ in a tdi vs a gti?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Springs
« Reply #6 on: November 26, 2008, 11:37:21 pm »
As above you must get the correct springs, TDi ones are normally rated for a higher noseweight from the obvious extra weight of the engine.
I would agree that 55mm is the most common fitment.
-45mm is a long way to go down IMHO, you'll end up scraping the ground quite a lot and if not caeful take the sump off.
Stu...
matt a
Re: Springs
« Reply #7 on: November 26, 2008, 11:53:36 pm »
Very few Golfs had 50mm struts, but you should be able to get your arm into to measure the circumference then divide by pi.
Offline MongyUk
Re: Springs
« Reply #8 on: November 26, 2008, 11:57:41 pm »
Can you go too low?? 45mm will be fine. Just about right. I had Apex springs before (on a different car)....said that it would drop by 45mm but was more like 30-35mm. If you can afford to pay a bit more well worth investing in something like the eibach sportline, or just go the whole hog and get FK coilovers.
Depends if you are a low whore like me or not?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Springs
« Reply #9 on: November 27, 2008, 12:04:53 am »
Of course you can!!
If everywhere you drive the car is scraping the ground or you can't get over speed humps then you are too low.
Stu...
Offline MongyUk
Re: Springs
« Reply #10 on: November 27, 2008, 12:12:58 am »
Thats the fun!!  It just makes you go the long way around. Muli-story carparks are a nightmare though!! Its all for show with no go anyway :)
Offline neg
  • gone old skool
Re: Springs
« Reply #11 on: November 27, 2008, 12:17:04 am »
 :happy2:  Standard GTI -> FSD's + H&R
Offline MongyUk
Re: Springs
« Reply #12 on: November 27, 2008, 12:32:40 am »
looks good :)
Offline MickMc
Re: Springs
« Reply #13 on: November 27, 2008, 09:01:45 am »
The car is a GTTDI , 45mm imo isn't too low , there are many people lower than that , just have to take your time over speed bumps and such  :signLOL:
Re: Springs
« Reply #14 on: November 27, 2008, 05:36:25 pm »
Well, it's your motor, matey, but I think Stu is just making a helpful point.
We look forward to hearing how you solved your problems and how much it cost you.
Perhaps the GT TDI is miles high as standard.
