Author Topic: Courtesy Light issue  (Read 1280 times)
Offline Palooza
« on: February 03, 2013, 01:15:10 pm »
I've just bought a MK5 and have an issue with the courtesy light..
When I open any of the four doors the courtesy lights doesn't come on. The courtesy light doesn't come on when the car is unlocked/key removed from ignition.
HOWEVER the footwell lights do come on in any of the above scenarios and it does show it on the clocks when the door is opened.
The lights on the courtesy light do work when turned on manually. I have tried making sure their is contact on the switch and I have checked the fuse.
What could be the issue?
« Last Edit: February 03, 2013, 01:41:03 pm by Palooza »
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Courtesy Light issue
« Reply #1 on: February 03, 2013, 03:10:35 pm »
Might be a stupid question, but have you checked the switch is set in the correct posistion? There are three settings. I think if it's pressed all the way to the left they are permanently off, all the way to the right is permanently on and left in the middle posistion they should just come on when opening doors etc.  :happy2:
Offline Palooza
« Reply #2 on: February 03, 2013, 03:52:31 pm »
Yeah mate I've made sure but I also tried it in each of the 3 settings just to make sure :)
Offline Kemnaychris
« Reply #3 on: February 03, 2013, 04:13:07 pm »
Had the same issue was the whole unit I replaced cost about 35 off ebay
2005 blue gray 140 gt tdi
Offline Palooza
« Reply #4 on: February 03, 2013, 04:51:05 pm »
It says in your sig you've got a 130? Did you have the issue on your mk4 or mk5? Before I go buy a light :)
