Author Topic: Slack gear lever, adjustable?  (Read 3225 times)
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« on: February 04, 2013, 02:05:14 am »
After having some unrelated work done at a local garage, I immediately noticed that the gear lever felt very sloppy, no real resistance or spring back in sideways movement.  Engaging gears is fine.
Is there any shaft adjustment / spring that can be serviced to get that usual GTI gear lever feel back?
A case of removing the gear surround... Or is it more involved?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Slack gear lever, adjustable?
« Reply #1 on: February 04, 2013, 10:26:13 am »
Try to 'reset' the linkages. Follow the steps at the end of this guide:
 http://www.forgemotorsport.com/media/Short%20Shifter%20Install(1).pdf
I recently installed a short shift so had cause to follow this procedure. I used a 5mm drill bit in the cabin instead of a nail.
'07 Red manual
« Reply #2 on: February 04, 2013, 10:35:45 am »
To improve it even more after that you can change the rubber bushes in t the cable ends to Design Draft 42 ones.  Nice Direct feel.
While your at it, the AKS shifter cable bracket bushes too  :evilgrin:
**Edit**
http://www.mk5golfgti.co.uk/forum/index.php/topic,32721.msg609965.html#msg609965
and then scroll 2 posts above to see them fitted  :happy2:  (you can also see one of the DD42 bushes in that pic)
« Last Edit: February 04, 2013, 10:42:23 am by Tfsi_Mike »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3 on: February 04, 2013, 10:38:05 am »
+1  :happy2:
'07 Red manual
Offline camfollower
  • -Receive: 31
« Reply #4 on: February 04, 2013, 11:29:13 am »
Great, thanks guys, will have a good read of those. :happy2:
Offline camfollower
  • -Receive: 31
« Reply #5 on: March 06, 2013, 04:45:55 pm »
Just to return to this again :) Do you reckon this is definitely the gear linkage bushings?
When in gear (any gear) there is horizontal play of about 15mm.
Where do you guys get your dd42 bushes from?  Direct from the states or is there a company in the UK doing them?
Also, anyone have part numbers for the standard bushes in case I hate the DD42 ones?
Offline gigolo456
« Reply #6 on: March 06, 2013, 05:26:27 pm »
Just ordered a set from Awesome GTi, c.£27.50
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: March 06, 2013, 05:32:03 pm »
^^^ If you have a forge short shifter, as far as i am aware you have to let them know   :happy2: as the pin hole for the forgew shifter if larger....
Silver is the way !
Offline camfollower
  • -Receive: 31
« Reply #8 on: March 06, 2013, 06:07:12 pm »
Cool, thanks, just ordered myself... don't have a short shifter so should be ok.
Let's hope they have them instock and not make me wait for 3 months! :laugh:
Anyone know the P/N for the standard ones?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #9 on: March 06, 2013, 06:09:26 pm »
I had to wait 3 weeks on mine  :signLOL:  but they did tell me that, when i asked, "when should i expect delivery"  :signLOL:
Silver is the way !
Offline camfollower
  • -Receive: 31
« Reply #10 on: March 06, 2013, 06:20:33 pm »
FFS, not this cr@p again, I swore I wouldn't order from Awesome again because of this.
I could open up my own online store with the same mentality... NO STOCK, just lots of products and nice user interface, then order on demand.
Argghh.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #11 on: March 06, 2013, 06:22:25 pm »
That was ages ago, but it is always good to phone and ask first, as we have all learnt in the past  :happy2:
Silver is the way !
Offline gigolo456
« Reply #12 on: March 06, 2013, 07:24:09 pm »
They did say they were in stock, but as I have ordered some THS side engine mounts as well (which arent in stock apparently), they will ship out everything together once mounts are in!! Bloody hope so anyway, booked to have everything fitted at Statllers a fortnight today!! :-o
