Author Topic: Brake fluid advice needed!  (Read 822 times)
Offline Cwm7
« on: February 04, 2013, 10:02:09 am »
Hi
Replacing front discs & pads this week along with a fluid change.
Looking at using Motul rbf600 & just wondering if its worth using this over standard fluid?
Any ideas & help appreciated.
Thanks :happy2:
2006 Black GTI 5dr Leather - Shark Stage 3, Neuspeed P-Flo, Autotech Internals, Pipewerx Down Pipe & Sports cat, Walk, Dog Bone Mount, Whiteline rear arb.
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Brake fluid advice needed!
« Reply #1 on: February 04, 2013, 10:14:40 am »
I just kept with standard.  Also it's definitely worth getting some penetrating oil/spray if you haven't already, those 21mm caliper carrier bolts can be a royal PITA to get off, especially after all the salt on the roads.
Offline DFish
« Reply #2 on: February 04, 2013, 12:16:34 pm »
If you're using standard brakes then I'd say overkill.
Fish
Offline Leesey
« Reply #3 on: February 04, 2013, 12:19:40 pm »
Fish
I kept with standard in my Cupra, but i only use it on the road and never break hard. Unless i really have too (Slow drivers moving into the 3rd lane :stupid: )
Offline S2 Ant
  • -Receive: 21
« Reply #4 on: February 04, 2013, 05:57:46 pm »
For normal usage the standard stuff should be fine.  The more expensive fluids are better aimed at track day usage I believe as they'll be able to better handle the abuse the brakes take and the higher temps involved
Ant
Offline exodus_ste
« Reply #5 on: February 04, 2013, 06:49:28 pm »
DOT4 ESP standard stuff is required. Preferably genuine VW aswell  :happy2:
Offline dokez
« Reply #6 on: February 04, 2013, 06:50:30 pm »
ate super blue
Offline Cwm7
« Reply #7 on: February 05, 2013, 07:59:11 pm »
Thanks for the advice, opted for VW DOT4, front discs & pads & fluid changed today, all seems good!  :smiley:
