March 10, 2025, 04:15:03 pm
All Things Mk5
Mk5 General Area
Brake fluid advice needed!
Topic: Brake fluid advice needed! (Read 873 times)
Cwm7
Taking part
-Given: 1
-Receive: 1
February 04, 2013, 10:02:09 am »
Hi
Replacing front discs & pads this week along with a fluid change.
Looking at using Motul rbf600 & just wondering if its worth using this over standard fluid?
Any ideas & help appreciated.
2006 Black GTI 5dr Leather - Shark Stage 3, Neuspeed P-Flo, Autotech Internals, Pipewerx Down Pipe & Sports cat, Walk, Dog Bone Mount, Whiteline rear arb.
camfollower
Won't Shut up.
-Given: 10
-Receive: 31
Cam follower awareness.
Re: Brake fluid advice needed!
Reply #1 on:
February 04, 2013, 10:14:40 am »
I just kept with standard. Also it's definitely worth getting some penetrating oil/spray if you haven't already, those 21mm caliper carrier bolts can be a royal PITA to get off, especially after all the salt on the roads.
Y'all gon' make me act a fool
DFish
Always Involved
-Given: 6
-Receive: 14
Reply #2 on:
February 04, 2013, 12:16:34 pm »
If you're using standard brakes then I'd say overkill.
Fish
Leesey
Taking part
-Given: 0
-Receive: 0
Reply #3 on:
February 04, 2013, 12:19:40 pm »
Quote from: DFish on February 04, 2013, 12:16:34 pm
Fish
I kept with standard in my Cupra, but i only use it on the road and never break hard. Unless i really have too (Slow drivers moving into the 3rd lane
S2 Ant
Won't Shut up.
-Given: 9
-Receive: 21
Reply #4 on:
February 04, 2013, 05:57:46 pm »
For normal usage the standard stuff should be fine. The more expensive fluids are better aimed at track day usage I believe as they'll be able to better handle the abuse the brakes take and the higher temps involved
Ant
exodus_ste
Always Involved
-Given: 14
-Receive: 11
Reply #5 on:
February 04, 2013, 06:49:28 pm »
DOT4 ESP standard stuff is required. Preferably genuine VW aswell
dokez
Always Involved
-Given: 1
-Receive: 3
Reply #6 on:
February 04, 2013, 06:50:30 pm »
ate super blue
Cwm7
Taking part
-Given: 1
-Receive: 1
Reply #7 on:
February 05, 2013, 07:59:11 pm »
Thanks for the advice, opted for VW DOT4, front discs & pads & fluid changed today, all seems good!
All Things Mk5
Mk5 General Area
