Author Topic: MFSW Retro Fit  (Read 8459 times)
Offline marko
Re: MFSW Retro Fit
« Reply #15 on: February 05, 2013, 04:59:40 pm »
what part number is the slip ring which should be ok???
sorry for hijack josh!!
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 636 0070
   Coding: 0000042
   Shop #: WSC 01279 785 00200
   VCID: 74EDE6EF1750D9B8354
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: MFSW Retro Fit
« Reply #16 on: February 05, 2013, 05:02:18 pm »
Yeah i realised it was you josh! Have you got a controller or do you need one?
Offline skard
  • -Receive: 245
Re: MFSW Retro Fit
« Reply #17 on: February 05, 2013, 05:15:07 pm »
   Coding: 0000042
BC suggests a type 2, so try get a type 2 highend other than AQ as some software versions of this have problems with cruise.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: MFSW Retro Fit
« Reply #18 on: February 05, 2013, 05:27:53 pm »
I fitted my old 974 clocks in his car, so he needs a new slip ring
Cluster and Key coding
Location Great Yarmouth
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #19 on: February 05, 2013, 11:16:27 pm »
No I need one of those!
I think Eddie is able to supply what I need?
Rainford Accounting Services
Tel. 07875505637
Email. jrainfordmaat@gmail.com
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #20 on: February 06, 2013, 03:22:46 pm »
im getting confused on what i need here...
i have bought a C version slip ring off eddie which he said i needed...
i have ordered a controller which i beleive i required also...http://www.ebay.de/itm/VW-Golf-5-jetta-Elektronikmodul-fur-Lenkstockschalter-1K0953549BG-MFL-/190794268931?pt=DE_Autoteile&hash=item2c6c398103
thats the one i have ordered (exact one)
do i need anything else? someone mentioned an airbag loom? do i need to order one of those also? im real confused! haha
Tel. 07875505637
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: MFSW Retro Fit
« Reply #21 on: February 06, 2013, 03:26:13 pm »
Stop worrying
You have a BG controller ordered which is for mfsw
You have a C version slip ring from me
You only need a mfsw loom and airbag cover if you didn't buy an airbag
Offline marko
Re: MFSW Retro Fit
« Reply #22 on: February 06, 2013, 03:30:53 pm »
 1K0 971 584 C
you need this airbag loom!!
omedyz on here has a few for sale if you dont want to use main dealer!!
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #23 on: February 06, 2013, 03:31:32 pm »
i bought this airbag + cover from a gent off here :
http://www.mk5golfgti.co.uk/forum/index.php/topic,60688.0.html
thanks eddie for your assistance!  :happy2:
Tel. 07875505637
Offline bigmig95
  • -Receive: 50
Re: MFSW Retro Fit
« Reply #24 on: February 06, 2013, 03:37:59 pm »
Josh bought my airbag Ed, the one you removed the other week   :happy2:
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #25 on: February 06, 2013, 04:30:36 pm »
thanks for confirming that mate!  :happy2:
Tel. 07875505637
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #26 on: February 19, 2013, 09:45:51 am »
ok had a bit of a headache with this over the weekend did me and joe!!
found i did actually need the multi function airbag loom...
also the slip ring we fitted doesnt seem to be working correctly, if couldnt register when my steering wheel was turning, we checked this through VCDS and the angle of the steering wheel didnt change when we where turning the wheel to full lock and back.
due to this it had caused my steering assist to fail and for some reason, turned my ESP off. so i had steering assist warning light and ESP warning light on my dash  :confused:
put the old CH controller on the error was still present, swapped the slipring back over to the old one again and after the left lock, right lock trick the errors went and my steering was back as normal!
has any1 experienced this before?
based on our findings as far as i can see the slipring is faulty and i will be in need of a new one!
Tel. 07875505637
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: MFSW Retro Fit
« Reply #27 on: February 19, 2013, 10:46:59 am »
basic settings need to be performed in most cases, when the controller is changed
Slip ring doesn't cause the steering fault, it allows communication with the steering wheel
The G85 sensor has photosensors that read the different size plastic tabs on the back of the slip ring as the wheel is turned
If the mfsw works and the horn then that would indicate that the slip ring is ok
I would try basic settings
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
Offline TheBIGJAYY
Re: MFSW Retro Fit
« Reply #28 on: February 19, 2013, 05:02:03 pm »
Hi Eddie!
thats great stuff thanks for posting mate!
i am missing the loom required for the multi function so ill get that ordered and we'll try again.
once again cheers for posting!!
Tel. 07875505637
Offline skard
  • -Receive: 245
Re: MFSW Retro Fit
« Reply #29 on: February 19, 2013, 05:33:27 pm »
I did mention on the first page you'd need this loom  :P
