Author Topic: Cruise control Leeds/Yorkshire area  (Read 606 times)
Offline GTI Leeds
« on: February 05, 2013, 09:21:05 pm »
Not sure if this is in right section or not.
Is anyone able to fit and program cruise control in Leeds/Yorkshire area?
Fancying having it fit and anything else that can be activated/programmed at same time.
If not is a long round trip down to see Eddie
Jono
Offline Steviedubs
Re: Cruise control Leeds/Yorkshire area
« Reply #1 on: February 05, 2013, 09:29:09 pm »
I have VAGCOM but ive never coded cruise in, if it's a case of just enabling it in long coding then it's no probs? I'm in Bradford too.
Steve
Offline Steviedubs
« Reply #2 on: February 05, 2013, 09:43:11 pm »
Just looked at the fitting guide and I should be able to do it no probs but you will need to make sure you have the right steering control module, airbag slip ring and the diag wire to the steering control module. Also I assume you've allready got the cruise stalk?
Steve
