Author Topic: Correct PCV Valve parts?  (Read 1202 times)
Offline vik2001
« on: February 06, 2013, 12:10:57 pm »
i have a edition 30 2007reg
i wanted to change all the PCV parts out, is there anything else that i need to do like hose pipes?
so far i have:
06F 129 101N for PCV valve
06F 103 483E for gasket
anything else parts wise for PCV i need to change that im missing?
« Last Edit: February 06, 2013, 12:30:19 pm by vik2001 »
Saintsteve
Re: Correct PCV Valve parts?
« Reply #1 on: February 06, 2013, 01:07:34 pm »
so far i have:
No just those should be fine  :happy2:
Offline vik2001
« Reply #2 on: February 06, 2013, 01:43:19 pm »
i just wanted to check i dont need:
PCV valve cover to turbo hose: 06F 103 215 B
PCV tube to turbo metal gasket: 06F 145 757 F
« Last Edit: February 06, 2013, 01:54:30 pm by vik2001 »
Offline vik2001
« Reply #3 on: February 06, 2013, 02:07:12 pm »
just spoke to VW they said the parts i need are as following:
06F 129 101L   - N is the new revision they said,  - £38  -
06F 103 483 E - gasket - £18
06F 145 757 F - tube to metal gasket - 92pence
breather hoses they said are not worth changing unless they are visibly leaking or cracked.
« Last Edit: February 06, 2013, 03:11:58 pm by vik2001 »
