Author Topic: Superpro bushings  (Read 1079 times)
Offline C4MKV
Superpro bushings
« on: February 06, 2013, 10:58:44 pm »
So, I'm looking to tighten up my handling and steering a bit and considering getting some Superpro suspension bushings which I believe might do the trick. I've already got a Whiteline anti-lift kit fitted (and sadly I haven't felt any difference with this) so just wondering what other bushings would be available to tighten up my 80k miles GTI for the front and rear?
  • -Receive: 427
Re: Superpro bushings
« Reply #1 on: February 06, 2013, 11:06:35 pm »
What about front and rear Anti Roll Bars and Engine mounts as well?
As for the bushes....
Front & Rear Suspension Bush Kit (road)
Clicky here
Offline C4MKV
« Reply #2 on: February 06, 2013, 11:17:19 pm »
Many thanks for the link! The next mods on my list are a set of H&R anti-roll bars and a Wavetrac LSD, so just looking for something to help with the steering feel at the same time
« Last Edit: February 06, 2013, 11:22:49 pm by C4MKV »
  • -Receive: 427
« Reply #3 on: February 06, 2013, 11:20:33 pm »
^^^^ You is Welcomes!  :happy2:
Wavetech is my choice for a LSD too.
« Reply #4 on: February 06, 2013, 11:30:25 pm »
- LSD.
- Anti-roll bars.
- Coilovers if properly set up.
- WALK.
- UNIbraces:  http://www.mk5golfgti.co.uk/forum/index.php/topic,48722.0.html
- SuperPro bushes:  http://www.mk5golfgti.co.uk/forum/index.php/topic,53579.0.html
All the above contribute to a sweet handling package.  :happy2:
Offline C4MKV
« Reply #5 on: February 06, 2013, 11:44:05 pm »
I just feel that my steering is feeling quite vague right now, like I can't really feel any grip response from the road, just wondering that once I've had the ARB's and diff fitted whether getting bushings done would make a difference?
Offline Baz300
« Reply #6 on: February 07, 2013, 07:53:41 am »
Drive a vauxhall for a day!
It will make you appreciate how good the steering feel is on your golf :laugh:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: February 07, 2013, 10:26:16 am »
Did you have alignment after having the walk fitted...
Alignment is key.
Diesel Daily Hack.
« Reply #8 on: February 07, 2013, 10:33:15 am »
....Fitting lightweight wheels will make a very noticeable difference but obviously depending on the alloy weight itself. I went from OEM Monza 18's @ ~11kg down to OZ Alleggerita 18's @ 8.03kg each. However, a cheaper alternative might be the TD alloys which weigh ~9kg IIRC.
But it's the combination of several mods which really make the difference - Modding is a very slippery slope!
EDIT: As Dom says, good alignment (not by your local KwikFit types) is a key factor and essential after a suspension mod.  :happy2:
Offline C4MKV
« Reply #9 on: February 07, 2013, 10:33:29 am »
Yep I did, at Awesome, and then again properly on a Hunter rig elsewhere!
