Author Topic: Engine removal and upgraded mounts install?  (Read 2975 times)
Offline tommygti
  • -Given: 22
« on: February 09, 2013, 01:20:33 pm »
I'm wanting to remove my engine to do some bay shaving and install some new mounts. I have a Haynes manual but just wondered if anyone's already done a similar DIY?
Offline james
Re: Engine removal and upgraded mounts install?
« Reply #1 on: February 13, 2013, 06:47:42 am »
really easy,  remove front end + rad pack,  remove airbox ect.  dissconnect loom from ecu and rest all cables on top of engine.    Drop drive shafts and remove gearbox links then undo engine mounts and the engine is out. :happy2:
Offline tommygti
  • -Given: 22
« Reply #2 on: February 14, 2013, 02:43:33 pm »
Quote
really easy,  remove front end + rad pack,  remove airbox ect.  dissconnect loom from ecu and rest all cables on top of engine.    Drop drive shafts and remove gearbox links then undo engine mounts and the engine is out. happy2
Ha, u make it sound easy. Take it you have already done this? I found a link that explains the procedure better than the haynes manual:
http://volkswagen.workshop-manuals.com/golf-mk5/index.php?id=5996
Apart from the obvious tools required is there anything else I could get to make the job easier
