Author Topic: New owner with a couple of questions...  (Read 2147 times)
Offline Richie_101
« on: February 09, 2013, 09:08:27 pm »
Hi All,
I bought a 55 plate GTI a couple of weeks ago, and I'm loving it. :wink: Having bought the first one I went to see, I've got no comparison/yardstick, so my question is about the standard exhaust & cabin noise.
I'm noticing that between 50-60 mph in 3/4th, and 70-80 in 5/6th there's more noise coming through into the cabin from the exhaust - over these speeds it does quieten off. I'd hesitate to call it drone (I used to have a VR6 with a stainless so I know a bit about that!), but it is definitely noticeable and has been commented on by others that have been in the car.
Is this normal? The exhaust is totally standard, but the car does have 99k on it, should that makes any difference.
Also, this is the first car I've had that uses 98 RON. Filling up yesterday the price was 10p/litre more than 95 RON (£1.35/litre vs £1.45/litre for V-Power). I'm not bothered about the extra few quid, but I just wondered if 10p/litre more is standard for V-Power.
Thanks in advance.
Rich.
Offline scottm72
Re: New owner with a couple of questions...
« Reply #1 on: February 09, 2013, 09:15:20 pm »
cant comment on the noise issue mate but the petrol sounds about right
just depends on the greediness of that specific garage, have a look when you are driving about etc as the differences will vary.
I find shell fuel expensive where i am esp for the higher ron stuff, i just use the teso higher ron ( cant remember its name ) dont know if it is any lesser quality than shell etc but i only use it as the other one where i live is morrisons and that's it.
I am up in Aberdeenshire.
PS, only time i notice a bad interior drone is if i have the back seats down or the parcel shelf off,
 :drinking:
Offline andygo
« Reply #2 on: February 09, 2013, 09:25:40 pm »
Tesco momentum is the stuff. Its generally ok. I use it in my race car, its meant to have a higher octane rating than v power.
Offline scottm72
« Reply #3 on: February 09, 2013, 09:29:15 pm »
yeah that's the stuff momentum  :happy2:
« Reply #4 on: February 09, 2013, 09:42:01 pm »
Both 99.  :smiley:
Offline doylebros
« Reply #5 on: February 09, 2013, 10:03:34 pm »
The noise would require a physical checking and could be just as simple as repostioning the exhaust or replacing a rubber mounting?
The fuel spec is on your petrol flap - it states the fuel specification but 95RON is perfectly fine. The car is equipped with knock sensors, which act in a fraction of a second to prevent knock. There's just a slight power increase if you use 98RON fuel as ur ECU will not be retarding the engine to compensate for the lower grade fuel. Having said that, I've never filled my car up with anything other than 98RON fuel.
  • -Receive: 427
« Reply #6 on: February 09, 2013, 11:00:20 pm »
The Power of V for me, every time!
Offline Richie_101
« Reply #7 on: February 10, 2013, 10:12:36 am »
Thanks for the replies. I'll check out the exhaust situation then and see if I can spot any potential issues.
Cheers,
Rich.
Offline Sel
« Reply #8 on: February 10, 2013, 01:43:14 pm »
I tend to alternate between 1 lot of Tesco Momentum 99 (it's only 5p more than Tesco standard) and Shell V Power (10p more than Shell standard) But in the past I have always avoided supermarket fuel, but reading posts on here people say its fine, but it still feels alien to put Tesco in.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: February 10, 2013, 05:12:05 pm »
With 99k miles, it will be well worth checking your cam follower.  :happy2:
Offline zooms3
« Reply #10 on: February 10, 2013, 06:19:27 pm »
Agree with above ^^^^^ deffo due one if not had one already! May well save a huge bill!
Offline Richie_101
« Reply #11 on: February 10, 2013, 07:45:16 pm »
Many thanks for the advice, I'll look into that. I've had a look at the DIY guide (http://myfastgti.com/volkswagen/threads/12734-DIY-HPFP-Removal-and-Cam-Follower-Replacement) and it's way beyond my capabilities. :scared: Any idea how much a VW dealer might charge to do that, and how often should it be replaced?
As I plan on keeping this car until it falls apart (well I would say that now as I've only had it 2 weeks!), is there anything else I should look into given the mileage?
The car has a FVWSH, the belt and tensioner were changed at 60k, brake fluid changed every second service, brake pads at 82k, air con was re-gassed at 92k, and a new clutch & flywheel were fitted at 98k.
Sorry if these are 'noob' questions, but everyone was a new owner once. :happy2:
Rich.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: February 10, 2013, 07:49:32 pm »
I personally wouldn't bother with taking it to a dealer for that. Buy the part from a dealer (around £25) then take it to a local specialist (ideally one mentioned on the forum) who will do it for a much better price - as they change so many  :grin:
Offline andygo
« Reply #13 on: February 12, 2013, 04:20:58 pm »
Unless you are terminally thick, changing the cam follower is easy, honestly. You can't really go wrong and once you have done that and gained a bit of confidence you can try other small jobs and save yourself a fortune.
Rich.
