Author Topic: Wipers stopped working :(  (Read 1379 times)
Offline Kemnaychris
« on: February 10, 2013, 12:06:02 am »
Hi any suggestions on what it might be ?
2005 blue gray 140 gt tdi
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Wipers stopped working :(
« Reply #1 on: February 10, 2013, 12:09:01 am »
Have you recently added after market HID lights. Also, have you checked the fuse to see if it has blown?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: February 10, 2013, 05:04:19 am »
Could be your bonnet latch sensor? If it thinks your bonnet is open then they won't work. Of it could be the wiper motor or as suggested above the fuse.
In order of expense I'd check the fuse first, then the bonnet catch. Get it scanned too to see if that throws up anything.
Good luck
PLANS: Stage 2+
« Reply #3 on: February 10, 2013, 05:23:52 am »
Good luck
^^ Was going to be my suggestion too...
Does your rear one still work?  If so I'd be inclined to think bonnet catch (when mine stopped working it was just because the bonnet wasn't shut properly  :ashamed:)
Vcds scan might make things easier too, anyone in your area have it?
Hope you get it sorted!
Offline Kemnaychris
« Reply #4 on: February 10, 2013, 10:29:44 am »
No hid mate :) yeah tried the 15amp fuse its still good even swapped it to be sure still nothing and bonnet is closed proper as always
It happened when driving it went half way up and then stopped :(
Thinking the motor has burned out
How hard are they to swap over ?
Cheers for the input guys :)
Yeah rear one works perfect
Offline Kemnaychris
« Reply #5 on: February 11, 2013, 10:44:03 am »
Away to just buy a new motor as the bonnet closes perfect and I slammed it few times :(
Is a motor hard to fit or ?
Any help would be ace cheers
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #6 on: February 11, 2013, 12:07:03 pm »
THe motor is fairly easy to get to and is located under the scuttle panel which is the black plastic trim under the windscreen wipers.
Offline Kemnaychris
« Reply #7 on: February 11, 2013, 12:25:22 pm »
Cheers :) yeah I hope it's a couple of bolts n that :) knowing my luck be a nightmare lol
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: February 11, 2013, 01:22:47 pm »
The wiper mechanism is easy to remove, getting the wiper arms could be difficult. What you need is a wiper arm puller, something along the lines of this would do the trick.
http://www.ebay.co.uk/itm/PROFESSIONAL-MECHANICS-ENGINEERS-WIPER-ARM-BATTERY-TERMINAL-REMOVER-PULLER-TOOL-/221123509168?pt=UK_Hand_Tools_Equipment&hash=item337bfcfbb0&_uhb=1
Offline Kemnaychris
« Reply #9 on: February 11, 2013, 02:22:32 pm »
Is that to remove the wiper and blade itself as had them off other week so come off easy :)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #10 on: February 11, 2013, 06:38:31 pm »
That is to remove the wiper arms. If you have had the arms off recently and they came off easily you shouldn't need a puller.
Offline Kemnaychris
« Reply #11 on: February 12, 2013, 11:46:07 pm »
Cheers yeah comes apart easy enough had to put it together many times now and again tomorrow :(
In the end it was not the motor that let go  but the actual arm and mech itself has seized solid no movement at all which led to main 25 amp fuse to let go aswell :( changed motor and arms never moved and with 2 of us pulling it side to side no movement so back to overpriced for a mech assembly in the morning
Hoping this sorts my issue out or car will be getting traded in for a newer model :-)
