Author Topic: RVC on ebay help  (Read 627 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
RVC on ebay help
« on: February 10, 2013, 05:08:11 pm »
Hi all.
Seen this on eBay. Not sure if I need anything extra to make it work in a mk5. Plus the part number has a Q at the end and the guide on this website says its an R at the end.
http://pages.ebay.com/link/?nav=item.view&id=180536231109
Anyone have any thoughts?
Raz
Offline Mandy
  • -Given: 95
  • -Receive: 94
  • -Receive: 427
Re: RVC on ebay help
« Reply #2 on: February 10, 2013, 05:24:29 pm »
Have you had a look on the guide on installing the RVC on here, gives all the part numbers and will give you an idea on what's what and what else might be required.....
~~ Clicky here ~~
Offline jbc
« Reply #3 on: February 10, 2013, 06:36:06 pm »
As above, SteveP guide tells you everything you need. SteveP used to make those wiring looms (for a small fee) so all you had to do was fit everything, but I don't know whether he still does them.
The eBay ad suggests all he is selling is the camera plus the video lead that runs to the rns510 but the picture has other wires wrapped around the video lead, so it's difficult to tell whether you will need to get a wiring loom as well or not. As the seller is selling this for retrofitting to a mk6, even if it has everything you need for a mk6, the loom for a mk5 is slightly different. I think it's only the connector for picking up the reversing light signal which differs (assuming the sellers wiring picks up the reverse light signal in the boot lid).
Think the best thing to do is to get the seller to confirm exactly what cabling you're getting for your money.
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: RVC on ebay help
« Reply #4 on: February 10, 2013, 09:36:04 pm »
Thanks guys. I'll email the seller. The guide shows so many more part numbers needed to fit it. I hope they supply them too as its a good price.
Sent from my GT-I9300 using Tapatalk 2
