Author Topic: Wrong springs??  (Read 1576 times)
Offline x21ekx
Wrong springs??
« on: February 11, 2013, 09:12:44 am »
Just bought a set of H&R lowering springs 35mm      Front: VA 29261-2VA
Rear: HA 29261 HA off a guy from eBay new unused its says on H&R's web site they fit mk5 golf mines the mk5 GT TDI which has a different part number?? I'm confused? Before I set about getting dirty does anyone know I these will be ok or not?
dpf out! Stage 2 remap.... Now it's gam'on!
Offline 2fast4you
  • Some drive to work... I work to drive!
Re: Wrong springs??
« Reply #1 on: February 11, 2013, 09:24:18 am »
They will fit 100% but the car may be lower or not lower enough  :wink:
Offline x21ekx
Re: Wrong springs??
« Reply #2 on: February 11, 2013, 10:16:08 am »
Cheers for that buddy puts my mind at rest
You think ill still be ok to roll on 19's  or should I op for 18's
Offline Matto
  • -Receive: 116
Re: Wrong springs??
« Reply #3 on: February 11, 2013, 11:48:12 am »
Just for info the H&R's I have on my GT Sport are the 29176-1's.
Offline gazon69
Re: Wrong springs??
« Reply #4 on: February 11, 2013, 11:55:38 am »
^^^^^^^ above part no is correct. They will fit but they might not lower it
Offline Kalpsn2000
  • -Receive: 56
Re: Wrong springs??
« Reply #5 on: February 11, 2013, 12:15:54 pm »
These are the ones I have on my GTI and they lower it by about 30mm. The box said these are also the ones for the GT sport.
I think the 29261's will lower less or not at all.
Offline x21ekx
Re: Wrong springs??
« Reply #6 on: February 11, 2013, 12:52:59 pm »
I'm lost now? How would it not lower it at all there 35mm instead of 30mm
I'm not sure weather to get the spanners out or not now??
Offline S2 Ant
  • -Receive: 21
Re: Wrong springs??
« Reply #7 on: February 11, 2013, 12:59:09 pm »
I can only assume suggestions of them not lowering it at all will be down to the springs being designed for a set weight. Different models will vary in weight, how much i dont know and am just guessing as to why the end result may be different.
Ant
Offline x21ekx
Re: Wrong springs??
« Reply #8 on: February 11, 2013, 01:46:10 pm »
Ahh I see! I really can't see that my car is so heavy that it wouldn't lower it plus the srings I have lower by 35mm and not 30 mm so surly that should compensate ?
Re: Wrong springs??
« Reply #9 on: February 11, 2013, 02:08:39 pm »
don't for get as well its not how low its going to go but the weight ratio of the springs as a tdi engine is heavier than a gti
Offline Kalpsn2000
  • -Receive: 56
Re: Wrong springs??
« Reply #10 on: February 11, 2013, 03:07:51 pm »
Based on this old sale thread they will fit (as already confirmed) and should lower by 30mm :happy2:
http://www.mk5golfgti.co.uk/forum/index.php?topic=21060.0
Re: Wrong springs??
« Reply #11 on: February 11, 2013, 03:14:36 pm »
they will fit no problem but they are for a gti/e30 so the wrong axle weight
« Last Edit: February 11, 2013, 03:20:24 pm by maxitrol »
Offline Kalpsn2000
  • -Receive: 56
Re: Wrong springs??
« Reply #12 on: February 11, 2013, 03:17:06 pm »
they will fit no problem but they are for a gti/e30 so the wrong axle weighted
Ah yes forgot about that.
