Author Topic: Mk5 multifunction steering wheel  (Read 2131 times)
Offline Robsta
« on: February 11, 2013, 08:22:44 pm »
 :driver:
Hi Guys
I have recently bought a mk5 gt tdi. Gti replica.
Problem is the steering wheel horn does not work, I have tested horn connections on the back of my airbag & horn connections are ok?
The wheel is a flappy paddle multi function.
Do I need parts?
Offline omeydz
  • -Receive: 50
Re: Mk5 multifunction steering wheel
« Reply #1 on: February 11, 2013, 08:26:17 pm »
Either you need steering wheel controller or airbag wiring harness for MFSW.
Basically you have got one and not the other so your horn doesnt work. Need to deduce this first before buying parts.
Check vagcom for coding errors too!! Job was only half done by the sounds of it by last owner. Do the MFSW buttons or paddles work?
« Last Edit: February 11, 2013, 08:27:50 pm by omeydz »
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Robsta
« Reply #2 on: February 11, 2013, 09:00:55 pm »
Non of the buttons work, where do I start do I need to find someone with a vagcom check unit?
I may try & find a normal gti wheel without multi function if its going to be a loads of hassle!
If I do need more parts will they need to be coded in?
Thanx for the advice.
Offline omeydz
  • -Receive: 50
« Reply #3 on: February 11, 2013, 09:38:45 pm »
Ideally if you can borrow a vagcom check your steering controller part number 1k0 953 549 ___ and cross check it here:
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
If its not a highline then to fix the horn and get your buttons etc working then get a highline steering controller from EddieNL on here.
If its a highline, then your airbag wiring is most likely the problem and needs MFSW wiring which I can help with supplying.
So initially a vagcom is pretty handy to have :)
good luck  :happy2:
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline Robsta
« Reply #4 on: February 12, 2013, 09:23:31 am »
Hi
I have a spare laptop with windows 7 32bit, is there a decent vagcom kit that's not too expensive?
Thanx for all your advice, will let you know what comes up after a vag check..
Cheers Rob.
Offline Robsta
« Reply #5 on: February 14, 2013, 05:28:50 pm »
May put steering wheel up for swap for a normal Gti without multifunction, would that work horn without coding or any other parts??
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #6 on: February 14, 2013, 10:34:44 pm »
VCDS is going to set you back £200-£250 but is well worth the layout. The other option is to find a forum member near you with VCDS, most will do a scan for beer tokens :)
THe other option is to replace the steering wheel with a non MFSW
Offline Robsta
« Reply #7 on: February 17, 2013, 09:11:58 pm »
Would do a deal with a ed 30 non mf
If anyone's interested
