Author Topic: ** UV Privacy Shades (3 door) **  (Read 37298 times)
« on: July 15, 2009, 12:26:22 pm »
I have factory blue tints on my car and love them, so the very idea of tinting just simply doesn't appeal, and these simply clip in and out in seconds
there's lots of retailers stocking these now, ebay too, all at varying prices. Noting here that this review is for the 3dr and not the 5dr so i wont be covering the function of being able to open the windows with them attached
i bought mine from here: http://www.palmautomotive.co.uk/ at a cost of £74.95 delivered
so what do you get for your money?
well the blind come in 4 sections, 1 for each side rear window and 2 for the rear hatch window. Also you get a zip up bag for storage, basic instructions and a couple of metal clips for use with the rears
basically the same 'mothercare' baby blind material you see on cars with the suction cups and silly pictures of winnie the poo etc
the quality is very good, and the metal frames have decent 'give' in them whilst staying perfectly in shape. here's a shot to show the thickness of the weave:
each blind has a material tab on it for you to grip when removing them
now for the fitting.
for the rear passenger glass keep the material tabs on the blind facing inside the car (working out which blind is for which side is pretty apparent)
holding the blind outside the window recess start by gentle bending and sliding it into place against the B pillar:
then gently ease the top corner in
and now the bottom
it's a compression fit, not mega tight so give you the ability to get it where you want it....and we're done
naturally the same process applies to the other side.
onto the rear
the kit includes 2 metal clips, one for each of the rear hatch window blinds and they just clip on
make sure you have the flat side facing the glass with them..like so..
now to fit them, pretty much a similar process to the rear windows. start with either one and work from the upper middle out
then the top corner (watch out for the plastic stump your parcel shelf string loops around, dont want to bend the blinds!)
and then carefully without scratching your plastics pop the metal clips home
and we're installed, again as with the rears there's movement to allow you to get them into position but once in they're very happy to stay there and wont come out until removed
This should take no more than 5 minutes to install or remove when needed and once in the bag they fit perfectly under the boot floor for safe flat storage  :happy2:
The questions i know you want to hear
what the difference inside the car?
well its is darker, not massively so but in a gentle way, here's a comparison. pic 1 is without and if you look at the glare on the interior plastics:
installed, no glare:
What's the visibility through them like?
looking at the pictures below you can see that you can still see through the car, and importantly preserve my blue outer tint, but everythings just that little bit darker :evilgrin:
perfect for the kids  :smiley: inside the car there is good visability although very mildly restricted over standard, but less so that with the factory tints, the shoulder of the car is high so my kids cant reach to see out anyway yet. saying this though, if you have tints already then this would be very very restrictive if you combine them with these
What is the view like for the driver?
very good. there's the join line down the middle, but easy seen past
and what you see in the mirror
Verdict
  • OEM looking
  • Easy to remove and store
  • Well made, should cope with kids grabing at them (if they can find the edge  :wink:), so durable
  • Car stays cooler in the sun
  • Filters up to 70% of harmful UV Radiation.
  • Theft Deterent - Privacy Shades for added security
  • Gives 100% coverage of passenger and rear windows
  • Easily removable - Better than Tinted Glass
  • Stops insects entering when window is down (5dr)
  • Anti Dazzle device against High Beam.
Hope this helps  :happy2:
Peace.
VC  :smiley:
« Last Edit: July 15, 2009, 11:36:41 pm by Very Cherry »
Re: ** UV Privacy Shades (3 door) ** By Very Cherry.
« Reply #1 on: July 15, 2009, 02:27:04 pm »
thanks for that fantastic review. not only are you a fantastically funny guy, you are a great contribution to the forum! ;)
« Reply #2 on: July 15, 2009, 02:34:52 pm »
cheers dude  :happy2:
these are the sort of things until you see in the flesh it's hard to tell what they're like from an advert such as this:
so you have to buy them blind (scuse the pun....again...  :laugh:). with a bit of luck if you've not seen these before, or even if you have and were unsure then hopefully this will allow you to make an informed spend with your money  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: July 15, 2009, 02:46:51 pm »
nice one VC  :happy2:
Maybe we should get some 'customised' with the forum address or other designs ? :evilgrin:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #4 on: July 15, 2009, 02:47:46 pm »
group buy?
« Reply #5 on: July 15, 2009, 02:55:17 pm »
But you had seen them.  :P
Nice little how to though.  :happy2:
« Reply #6 on: July 15, 2009, 02:57:23 pm »
indeed dude indeed  :wink: i wouldn't have known of them or considered them until seeing them on yours at inters  :drinking:
WILLZIE
« Reply #7 on: July 15, 2009, 03:13:35 pm »
Superb review and timed perfectly!
Some people we know have just had a little one and want some shading for her, to which I told them about this product....... Now I can show them in excellent detail VC!  :happy2:
Phil Mcavity
« Reply #8 on: July 15, 2009, 03:54:22 pm »
Great product isnt it Vc. well worth the money , and nice write up :happy2:
« Reply #9 on: July 15, 2009, 05:04:30 pm »
Cant see any pics of this, but i am sure its a great review. The title is making me snigger evrytime i scroll past it, it sounds like a Perfume logo
And now for your delictation the new splitter with added down force for tha special track day by very Cherry  hee ho hee ho  :laugh:
Offline CarrG
« Reply #10 on: July 15, 2009, 05:51:18 pm »
Cheers VC spot on.   :happy2:
We've ordered some for our touran and young girls and your review has answered all the Mrs questions!
K1 Revo 2+
Ibis RS3
« Reply #11 on: July 15, 2009, 06:11:42 pm »
Excellent review (as is your review on the deflectors).
However, I would need to see some in the flesh. They look fine from outside the car but I live inside the car and don't like that retro rear split-screen (unless I had an American V8 under the hood). They also look a tad baggy a la mosquito netting.
No-one under the age of a teenager rides in my car, so no need for shading.
Anonymity through the rear screen is attractive though.
Deflectors for me but not these methinks.
:happy2: 8) :happy2:
WILLZIE
« Reply #12 on: July 15, 2009, 06:19:27 pm »
they've gone up in price quick-£86.95 +VAT  :surprised: :surprised:
Thats alot of money for them!!!
« Reply #13 on: July 15, 2009, 07:07:22 pm »
no not cheap at a
they do fit pretty snug, they may look baggy but they sit nice and flat  :happy2:
but i hear what you're saying, more suited for those with small very cherry minime's kids tbh, although an option for others if they float the boat  :smiley:
« Reply #14 on: July 15, 2009, 07:08:49 pm »
is that for the 3dr?
if so then ouch, but i can say they are excellent quality, and although pricey they will last, so a worthy investment if your looking to shade the rear
