Author Topic: Quick Info Needed on CAM FOLLOWER  (Read 1832 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: February 12, 2013, 11:13:43 pm »
Hey up guys, just been using the search bar for more info on Cam Follower, was going to get it done at Statllers next week, but a lot of people say its quite easy to change.....is this the case.
Some people say its hard on an 05 or 55 plate (something to do with a Banjo Clip) and some people say harder with DSG? any of this true?
So.....Worth doing my self, im quite handy with stuff like this...but cant be arsed with it going wrong?
Also, i found a part number, looked like a revsion C, is that the latest one or is there a newer part number.....please leave below if you know it..
Cheers guys.
Re: Quick Info Needed on CAM FOLLOWER
« Reply #1 on: February 12, 2013, 11:19:31 pm »
What year is your car?
If earlier than an 07 I would let  Statllers do it as you'll most likely have a banjo bolt to contend with.
btw having dsg doesn't make the job harder.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: February 12, 2013, 11:22:14 pm »
C is the latest revision.
'07 Red manual
  • -Receive: 427
« Reply #3 on: February 12, 2013, 11:26:14 pm »
Part number is 06D 109 309 C. There is a very useful section now filling up with part numbers on here and an equally helpful "How to" guide thread. These are from there, so don't thank me....
Cam Follower Change Write Up
Cam Follower Change Vid'
Which reminds me, I've got about 50 P/N's to dump there....... :nerd:
« Last Edit: February 12, 2013, 11:28:46 pm by MC71 »
Offline GTI-Ross
« Reply #4 on: February 12, 2013, 11:27:11 pm »
Its a 55 plate, does the Banjo really make it that much harder....thinking that £50 could go towards my remap  :drool:
Offline GTI-Ross
« Reply #5 on: February 12, 2013, 11:32:45 pm »
See that look piss easy, but one guy on here messed it up bad. Engine fluid was pissing out every where when he started the ignition. Even though he believed he had every lined back up perfect .....Hummmm....tough choice on what to do.
Any videos changing Cam Follower with the Banjo clip?
« Reply #6 on: February 12, 2013, 11:35:32 pm »
Ohh no you dont....  :signLOL:
« Reply #7 on: February 12, 2013, 11:49:42 pm »
For the banjo bolt you firstly need the correct tool to use in the confined space and are likely to drop something. If you feel adventurous then give it a go but what happens if you're stuck?
btw that link for doing the job isn't for a car with a banjo bolt.
Offline Baz300
Offline GTI-Ross
« Reply #9 on: February 13, 2013, 04:10:25 pm »
Offline andygo
« Reply #10 on: February 13, 2013, 04:31:24 pm »
Its really easy to do. If your worried about dropping a bolt, make sure you place a large cloth under the area your working on. Its a 10 minute job tops. Best done on a cold engine though.
What could possibly go wrong?
 :rolleye:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #11 on: February 13, 2013, 04:33:50 pm »
'07 Red manual
Offline Baz300
« Reply #12 on: February 13, 2013, 05:18:38 pm »
http://myfastgti.com/volkswagen/threads/12734-DIY-HPFP-Removal-and-Cam-Follower-Replacement
Doesnt say if it an 54 - 55 plated thought, can see any extra instruction about the banjo clip.
That is for the earlier cars, he removes the banjo bolt with the m8 spline taped to the spanner.
The later cars have a rubber pipe to remove instead.
Offline ianv5
« Reply #13 on: February 13, 2013, 05:24:37 pm »
Mine is a 55 plate with Banjo bolt. Could not do it myself as you need the correct torx to undo and they are really hard to find, cost of purchasing would be better spent getting an independent  dealer to do it for you.I got mine done at AKS tuning for £30 notes. Thanks again Alex :happy2:
Offline Luka
« Reply #14 on: February 13, 2013, 05:30:10 pm »
M8 spline bit needed to undo the banjo bolt, wrap it in some tape and put it in a ratchet spanner, the tape will stop it falling out. As said, 10-15 minute job.  :happy2:
Sold - 2006 Tornado Red GTI 3dr
