Author Topic: Edition 30 steady speed fuel consumption?  (Read 3230 times)
Offline andygo
« on: February 13, 2013, 04:23:44 pm »
I know there are several threads about fuel consumption but maybe it could be done slightly differently..
Whats your ed 30 fuel consumption indicated at a steady 50 and 60 mph in 6th gear.
After zeroing at the required speed, mines an indicated 34 ish and 31 mpg respectively using cruise control. I think that seems to be poor tbh even though mine may be mapped. Speed for speed and on a steady throttle mapped/unmapped should be similair I'd have thought.
Saintsteve
Re: Edition 30 steady speed fuel consumption?
« Reply #1 on: February 13, 2013, 04:28:14 pm »
I know my bluefin at stage 2 doing 70 is 30mpg bang on.
Edit..
Based on the end of the journey figure...
You will see higher but depends if your coasting or driving up a continual incline .
« Last Edit: February 13, 2013, 05:32:30 pm by Saintsteve »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: February 13, 2013, 04:28:54 pm »
Mapped / unmapped was the same at steady throttle for me (I saw what my tuner was doing with the map)
Those figures are a little poor as my GTI would do high 30s / early 40's at 70mph with cruise on
Offline sanj
  • -Given: 17
« Reply #3 on: February 13, 2013, 05:29:32 pm »
Mine at those speed's would be in the high 30's so your's is a little low,but do take the cold weather into consideration! :smiley:
Offline Tamiyoman
  • -Receive: 39
« Reply #4 on: February 13, 2013, 05:31:39 pm »
33mpg @ 60mph, 29mpg @ 80mph stage 2 Ed30.
Offline andygo
« Reply #5 on: February 13, 2013, 06:16:52 pm »
They drink like a thirsty thing, lol!
 :drinking:
  • -Receive: 291
« Reply #6 on: February 13, 2013, 10:56:24 pm »
If I zero the mpg counter once I hit the motorway and stay at 60mph, I get around 42-44mpg.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #7 on: February 15, 2013, 12:03:28 am »
There is a 4 mile stretch just outside of town that I went each direction resetting the avg mileage at each start.
Both directions with cruise control at 50 mph(actually held at 52.5 because I know my speed is 2 mph slow):
1st) going out = 38.3 mpg avg
2nd) coming back = 35.5 mpg avg
Average of 36.9 mpg....
« Last Edit: February 15, 2013, 12:05:29 am by ROH ECHT »
Offline andygo
« Reply #8 on: February 15, 2013, 10:55:16 am »
I have just cleaned my MAF with brake cleaner and wow!
50mph = 38mpg, 60 mph 37mpg.
Allowing for a bit of temp variation, thats still a huge difference from my low 30's of before.
Saintsteve
« Reply #9 on: February 15, 2013, 10:57:30 am »
Is that the best thing to clean the MAF?
Offline andygo
« Reply #10 on: February 15, 2013, 12:49:29 pm »
Probably not, but its what I have in the garage! It seems to have worked (or at least done something) ok at the mo though.
Offline Ash_SteadyEddy
« Reply #11 on: February 15, 2013, 06:08:01 pm »
Stage 1 and I average around the 34mpg mark one a motorway run.
Edition 30 No.1995 P-Torque stage 1, ITG Maxogen, Eibach Sportline, RNS 510
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #12 on: February 15, 2013, 11:36:41 pm »
I cleaned the maf with maf cleaner and it still went out. Best thing is to check what your intake air mass is and if the IAM< 0.8(BHP)(g/s)
for a 200hp gti 200*0.80=160g/s
So if you don't reach that you should only then clean it to see if that makes a diff. If not then you need a new maf.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #13 on: February 15, 2013, 11:38:25 pm »
Today I had a 9 mile stretch beginning and ending at the same elevation and it averaged 35.5mpg at 55mph with cruise on.
The road was a route through the countryside on the way home and has twists and humps.
« Last Edit: February 16, 2013, 02:00:22 am by ROH ECHT »
