Author Topic: Aston martin calipers  (Read 3809 times)
Offline jimk04
« on: February 13, 2013, 10:24:25 pm »
Canb anyone help with details on these.?!
Db99 fronts arere the norm to use?
Db9 rears any good?
Disc sizes for them?
Wheel clearances??
Part numbers to look for.
Db9 same as vantage v8 caliper wise?
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline jimk04
Re: Aston martin calipers
« Reply #1 on: February 13, 2013, 10:26:10 pm »
What advantages over the usual porker 4 pots?
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: February 13, 2013, 10:40:43 pm »
Fronts only.  Rears are same as mk1 lcr.
You can run them with 345mm discs with custom brackets.  Same brackets I have on the vRS.  Clearace isnt great with that setup. 3mm spacers on a pro race 1.2.
Or use the 362mm kit which fits with no spacer and 5mm clearance on a pro race 1.2.
Advantage over porka brakes is there are more disc choices other than the 350mm merc disc.  Otherwise they both work well.
Meant to be better with a master cylinder upgrade.  Im fitting my new kit without the ms upgrade first,  then the ms upgrade will be fitted so I can give a decent opinion on it.  My kit has the same piston size as the db9.
Follow AKS tuning on Facebook
« Reply #3 on: February 14, 2013, 03:57:41 am »
Alex don't you have some spanking new black DB9 calipers?  :party:
Offline jimk04
« Reply #4 on: February 14, 2013, 06:26:39 am »
So they are slimmer....if useable over the vag 345?
 Any part nos to look out for?
« Reply #5 on: February 14, 2013, 07:29:51 am »
Stop right there James, you want 996TT Calipers!  :mad:
 :innocent:
Offline jimk04
« Reply #6 on: February 14, 2013, 08:14:41 am »
Lol yeah iI know :grin:
Offline taff-turbo
« Reply #7 on: February 14, 2013, 10:42:59 pm »
i believe these are the same as 996tt's
http://www.ebay.co.uk/itm/Genuine-Porsche-911-Carrera-S-Front-Brake-Calipers-Red-Brembo-2008-/290860409571?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43b8a1a2e3
i want them too but won't get around to it in time  :sad1: so hopefully someone else on the forum might benefit  :happy2:
« Reply #8 on: February 15, 2013, 06:25:31 am »
I know someone wanting to bid on these so maybe best to de-conflict so not to drive the price up  :happy2:
Offline jimk04
« Reply #9 on: February 15, 2013, 07:55:12 am »
Yes iI havehave beenbeen inin touch with him already!
Offline taff-turbo
« Reply #10 on: February 15, 2013, 04:28:56 pm »
good idea  :happy2: maybe an idea for a new section on the forum, might save us all a few quid  :wink:
maybe  not so good for the seller........  :signLOL:
